Question about Zenith R50W46 50" Rear Projection Television
Model R50W46 I have a problem trying to find codes for the Directv. I want to use the remote for the Tv instead of using the Directv remote. But cannot find any codes that work the directv. I am wondering is there any codes out there that will work? or am I stuck useing 2 remotes?
    President:
  • 3,130 Answers
Try to use the manual search on the remote. If you do not find the code that way, then you are stuck using two remotes as if the set is compadable with that remote, it will be pre preogrammed into the remote as you do not program the remote. You only retrive codes that are already in the remote.
Posted on Apr 29, 2007
SOURCE:
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
Need code & instructions for Emerson TV. I have universal remote
Hello
Codes for Emerson TV with "Direct TV - RC64 for web Univeral remote control are:
10154, 10236, 10463, 10180,
10178, 10171, 11963, 11944,
11929, 11928, 11911, 11394,
10623, 10282, 10280, 10270,
10185, 10183, 10182, 10181,
10179, 10177, 10158, 10039,
10038, 10019
You haven't specified the model number of remote control you possess; that is why I send this remote controls codes.
[1] Locate the 5-digit code for your DIRECTV® Receiver
[2] Power on the DIRECTV Receiver
[3] Slide the MODE switch to the DIRECTV position
[4] Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
[5] Using the number keys, enter the 5-digit code. If
performed correctly, the green light under the
[6] Aim the remote at your DIRECTV Receiver and press
the PWR key once. The DIRECTV Receiver should
turnoff; if it does not, repeat steps 3 and 4, trying each
code for your brand until you find the correct code
OK.
Jul 02, 2011 | Emerson Televison & Video
I have a Toshiba 37" LCD Model 37E200U no code seems to work with my Direct TV Rc64R remote control any ideas ?
I can help you with your Toshiba TV & DirecTV remote control.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, & 11971.
There are so many codes to try for Toshiba and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
Jun 05, 2010 | One For All URC-3021 Remote Control
Remote code Directv
try vizio under tv tv brand in the direct tv remote control codes.
Aug 02, 2009 | Honeywell CE2Y-PPT Remote Control
TV Remote code issues
If you go to Directv.com and go to the remote control programming section you can put in the make and model of the tv and it will usually come up with a specific code that may work. I hope this helps a little bit. :)
Mar 31, 2009 | Panasonic EUR7603Z9A Remote Control
I have a Directv RC24 remote control. I am trying
1. Locate the DIRECTV Receiver's brand and model number
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
6. Using the number keys enter the 5-digit code. If performed
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Zenith R50W46 50" Rear Projection Television Logo
127 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
