Question about Tomtom One XL GPS Receiver
Tomtomone suction base wont stick to anything
Ive cleaned both surfaces with window cleaner, soap/water,warm cold no help
Thanks FIXYA, Your desire for my $$ seems to out weigh your concern for my problem/solution. Rather than tossing $ 20 bills at you dope smokers, I think I will spend my $$ on a real solution. Then i will tell my friends for free. OUT!!!!!!!
Posted on Dec 26, 2008
Why doesn't the water pick up on my carpet shampooer???
Hi Julie! If the cleaner is not picking up the dirty water this usually means something is not sealed off properly. Try these steps below to restore suction to your cleaner.
1. Remove the clean water tank. Recline the handle & let the handle lie down on the floor.
2. Remove the dirty water tank. Check that the dirty water tank cap is on the dirty water tank and tightened closed.
3. Clear the filter screen of any hair or debris.
4. Remove the nozzle. Clean the nozzle of any hair or debris.
5. Located on the machine behind the nozzle is a 2nd filter screen. Clean it of any hair or debris.
6. Replace the nozzle.
7. Replace the dirty water tank. Press down on all sides so that it is flush to the cleaner base.
Give it a try! The suction should be restored to your cleaner. If not I have included a video link where you may view these instructions. Hope this helps! Loss of Suction Won pick up Hoover Max Extract 77 FH50230 FH50222...
Nov 02, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
The wainscoat in our bathroom was painted with oil base paint.I would like to repaint it with latex paint. Is there anything I need to do to be sure this will work?
All that is needed is to lightly sand and remove the dust. The issue comes when you try to put oil over latex. Oil is brittle and has problem sticking to waterbased products that have greater flexibility.
If you want to skip the sanding, you can use a adhesion promoting primer like Bullseye 123. Regular Killz won't work. Make sure it is an adhesion promoting primer.
Also make sure your surface is clean. Warm soap and water with a clear water rinse is acceptable.
Feb 01, 2011 | Valspar Corporation Valspar Signature...
It isnt puting any liquid down
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
It won't dispense water or suction it up
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Tomtomone stuck with frozen screen and wont switch off can switch off using the reset button but when switched back it sticks on the tomtomone screen
Your TomTom home software is corrupted:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) Check the health of your Tomtom One flash drive: connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem.
3) Restore software: using TomTom Home, restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom ONE GPS Receiver
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
What is best for cleaning the screen of a rear projection tv?
A mild detergent soap and hot/warm water.
Use it in moderation.
Mix up some dish washing soap and warm/hot water in a bowl. Use a lint free cloth and dunk it into the water and then wring it out. Wipe the screen down and repeat until clean.
Then use plain water to wipe the screen (on a wringed out cloth) to remove any residue until you have purged and dried the screen.
Tips: Make sure you use a lint free and soft cloth. Make sure you wring out the cloth so that you only have minimal water or soap on it.
DO NOT use alcohol or ammonia based cleaner on the screen.
Expect to spend around 10-15 minutes to properly clean the screen.
Jan 23, 2009 | Televison & Video
Tomtom One XL GPS Receiver Logo
37 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
