Question about Maytag Washing Machines
Maytag mtw5870twd washer
Machine starts agitating as soon as filling begins. Also agitates while filling for rinse. During the final spin water is continuously filled leaving clothes very wet at the end of the cycle. From past experience i thought the timer was defective and replaced it with no change. My wife says it also sometimes leaves water on the floor. I am stumped can you help?
eandlfan
  • 9 Answers
SOURCE: Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Posted on Dec 23, 2007
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
mikedurland
  • 481 Answers
SOURCE: trouble shooting kenmore washing machine 80 series.
if it agitates in the first rinse but not he second then it may be the timer.
a little more details would help.
Posted on Jun 27, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool LSB6300PW2 Won't Agitate or Spin
if you lift andclose the lid do you hear "clicking" noise??? i bet not. simple repair, lift the lid and with a hollow shafted screwdriver(1/4in nutdriver or similliar hollow shaft implement)you fell with your hand the bottom half of the left side lid hinge. as you open and close the lid you can fell the opposing end of hinge under the top no need to dissasemble you can fell it right there. when you find it simply slip the hollow ended shaft over the hinge and apply pressure towardds the rear of unit.While doing this the top will want to close( your pushing against the hinge).. after appling slight pressure youll bend it slightly, enough to activet the lid switch mounted to the rear of the main lid assy.
Posted on Nov 13, 2008
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Won't finish the final spin
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Post further comments for more information ....
Good Luck!!
Thanks
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
As washer was on final spin cycle it sounded like a belt came....
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Kenmore Washing Machines
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
