Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 6930 does not boot up right
The computer starts up and says configuring upgrade stage 3 of 3 -0 percent and never goes past 0 percent then shuts down and starts over with the same thing. just repeats and repeats.
Acer aspire 6930 will not boot
restart the laptop then at the time of booting press F8 / F2 then a screen shows and there shows " Last knwon good configuration " go over this select and press enter ur system will be boot .
If ur system not boot in this process then take backup and format the laptop.
Oct 07, 2012 | Acer Aspire 6930-6455 Notebook PC
DURING A VISTA SERVICE PAC UPDATE THE POWER WAS INTERRUPTED
try rebooting with a window boot cd or Vista cd...GL
Nov 21, 2009 | Computers & Internet
I have a aspire 6930 laptop from acer it will boot past post but not into windows not even in safe mode it just goes to green bar like windows is starting then blue screen with error stop:oxoooooo7b...
id reinstall vista ! if you want to do this you need to get in to the bios which u press F2 i believe when the comp first starts up when your in the bios scroll along to boot menu u shud see a boot list with your hard drive at the top ,you need to change your dvd drive to the top so itll boot from dvd , restart your computer with a windows vista disc in the dvd drive and i think it shud give you an option to fix your system if doesnt work then definitly do a clean install of vista using your product code . hope this works
Oct 18, 2009 | Acer Aspire 6930-6082 Notebook PC
When I turn on my computer the screen reads configuring updates: Stage 3 of 3 0% complete. Do not turn off your computer. Then it goes to shutting down. It starts up with acer, microsoft corporation the...
downloads are either being stopped by a firewall or your system cannot update what it needs to because your missing other updates. if you dont have all required updates some others will not install.try automatic updates.download all critical and recommended updates.
Oct 05, 2009 | Acer Aspire 9410 Notebook
Acer Aspire 5735Z - Vista Home Prem. shutdown hang
updates can be slow,and lead to more updates sometimes.you should goto windows update,let it search for important updates then install them.even if it takes a while,once you do that it should be fine.and configure updates to auto download but ask to install.
Sep 20, 2009 | Acer Aspire 5735-6694 Notebook
My Acer aspire 6930 doesn't boot up!
sounds like windows are possible hard drive problem
Mar 29, 2009 | Acer Aspire 6930-6771 Laptop
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
How do i activate blutooth on my acer aspire 6930?
Have you looked to see if there is a bluetooth software bundle that came with your computer? If there is it should be as easy as finding the program on your computer that runs the software. Once you locate the program you'll have to setup the software with your bluetooth device. If you do not have a bluetooth device, setup will not work as it needs the device to automatically sync with your computer.
Dec 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
