Question about Ovens
Magic chef electric oven...went to change clock settings, while oven was on and ab 5 appeared on screen, oven shut off and now can't do anything w/ it. Tried pushing cancel, bake, broil, timer and clock w/ no luck. Can't cook Christmas ham now and I don't have a manual. Help!
How do I replace the oven heating element in a Magic Chef oven?
Posted on Dec 31, 2008
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
I wanted to change the time hour. I pushed clock and up arrow at a time and the clock is showing 5 AB. The screen is frozen. I can't use any options. How could I get it back to normal? Thank you for your...
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Nov 20, 2010 | Magic Chef 9112 Gas Double Oven
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Apr 04, 2010 | Magic Chef Ovens
Code F-3 or F-5 appears when oven heats
this is usually a temp sensor probe problem.check you wiring between the probe and the electronic control board. at room tempt check the resistance on the probe if it less than 500 ohms replace the probe.
Feb 23, 2010 | Magic Chef 9512 Electric Single Oven
No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
Dec 11, 2009 | Magic Chef 9815 Electric Single Oven
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Re-set Clock due to power black out
Lucky for you(?) I had to reset our clock for daylight savings and checked here before i found my manual. If you're still looking for an answer, press the + & - buttons at the same time, let go and you have 4 seconds to press the + key again to set the time
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Dec 27, 2008 | Magic Chef 9512 Electric Single Oven
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
Magic chef stove and oven installed 1978
Yes this is normal. you can use that burner to keep things warm without turning it on, saves energy.
Dec 14, 2007 | Magic Chef 9512 Electric Single Oven
Ovens Logo
570 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
