Question about HP PSC 1610 All-In-One InkJet Printer
Remove and check right cartridge (black ink)
I printed fine all day yesterday. Then I came in this morning and wanted to start printing again. and I get the signal "remove and check right cartridge".. I did that several times, nothing worked. Then I put in another "used" cartridge that I get from Cartridge World here in Durham, Carolina and I get the same signal. Then I put in a third "used" cartridge and it works fine. But then suddenly, as in the past, the cartridge will stop working and I have the same problem again. This printer is about 4 years old and I have never had any problems at all. I do use it practically every day. I think now I need to look into a new printer. Or do I need to buy NEW cartridges? I don't know what to do. Please help me.
  • Anonymous Dec 29, 2008
    my printer show the message "remove and check right cartridge" all time and i can not print my work.
I have discovered how to perform a full reset of the HP PSC 1610, which clears all the internal memory, thereby fixing the "remove and check right cartridge" problem.
To perform a full reset of the HP PSC 1610:
1. Unplug the power cord.
2. Press and hold the OK and CANCEL buttons on the front panel keypad.
3. While still holding the buttons, plug the power cord back in. Continue to hold the buttons for two seconds, and then release them.
4. After a few seconds, the screen will display the message “Deriv Clear” confirming that the reset is done.
I have discovered that the HP PSC 1610 all-in-one printer has a hidden diagnostic mode, which lets you do several interesting things.
To enter the hidden diagnostic mode of the HP PSC 1610:
1. tap both arrow keys simultaneously.
2. tap the left arrow key.
3. tap the OK key.
4. At this point, you have a choice to make. If you want to enter the "Service" menu, tap the left arrow key. If, on the other hand, you want to get into the "Underware" menu, tap the right arrow key.
There is a menu option in the "Underware" menu called "printer-mech button tap", from which you can initiate any of HP's "tap tests," so called because, on the early HP printers whose onboard user interface was limited to two physical buttons, you would tell the printer which diagnostic test you wanted it to perform by holding down one of the buttons while tapping the other button a certain number of times. In the HP literature, the various diagnostic tests that the printer can do are named according to the number of button taps required to initiate the test. Hence, HP might refer to "tap test #6", "tap test #9", and so forth.
I am not sure what all of the various tap tests do, but I would imagine there is probably a tap test that resets the internal counter responsible for making the printer reject the cartridges.
Posted on Sep 16, 2009
I put in a new black ink cartridge in my epson stylus printer. The irst page I printed was very light & spotty in printing. Now there is no print showing on "printed pages" What can I do? I cannot...
Hi Good day!! try the Head cleaning.. to do that follow this method:
1. Click Start
2. Click Settings
3. Click Printer and Faxes now you should view your installed printer.
4. right click your printer and then properties.
5. click "Printing Preferences" and the Printer preferences box there are 5 tabs Choose the "Maintenance"
6. Click "Head Cleaning" to start the cleaning. and then try to print again see if your printing was fine..
if not you should start the head cleaning again..
Regards:
JR
Oct 07, 2010 | Epson Stylus 880 InkJet Color Printer
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Use on black cartridge
When you start to print out a job or document, the job starts with the print box. Your default printer will appear in the drop-down box. To the right of that box is the properties box, open it with a click. The top tab marked COLOR is selected and you want to select the block, "print in grey scale only". When you start to print another job, the greyscale will have to be set again and again. Some printers will let you remove the color Cartridge and print only in B&W, but not many. (some HP's)
Apr 05, 2010 | Dell 924 All-in-One InkJet Printer
Have changed the black ink in the printer as it was displaying error code 4. It is now displaying error code 5! What does this mean. What should I do?
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer doesn't print black
if the cartridge is not flowing...I would NOT soak it in water as that can flow back into the cartridge...remove it and use a q-tip with rubbing alcohol to clean...then you can use toilet paper to rub across it to make sure its flowing...you should get a solid black line...be sure not to touch where the electronics connect to it...if you do, clean it with the alcohol also
Aug 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Changing cartridge on printer
The Basics manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge.
7. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment sheet.
Note If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
choose your country/region, and then click Contact HP for information on
calling for technical support.
Jan 03, 2009 | Office Equipment & Supplies
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
2,075 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
