Question about iLO 3200 32 in. LCD Television
My ilo 32 HD no longer works
The TV no longer responds to any of the controls, volume, choice of input, numbers, etc.., except on and off, The On and Off is also only workable through the physical switch and the remote. it also goes to either a blue screen and "blanks out" for about 30 seconds to 1 minute, or simply will just show fuzz with a noisy background.this happens so often it is intolerable as a device.
I want to fix this TV, its great, but its broken. What should I do? I have and had the TV hooked up to a high technology surge protector, which my computer systems were hooked up to, but the TV is the only issue.so I doubt thats what the problem is.
What should I do?
The Product Number is BEH61404063T4
Sincerely,
Gabriel Mattice
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try the basics:
  • new battery on the remote;
  • check all connections (cable TV, RCA connectors from receiver/decoder box, DVD);
  • hard reset by unplugging from the mains for an extended period of time not only minutes;
  • check if any of the buttons on the front panel control are stuck; flick/tap with your finger nail;
  • the blue screen is indicative of video mute, the TV is not receiving an intelligent video signal, try other video sources;
  • postback exact model number to determine any known/common issues.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 25, 2008
  • 2,427 Answers
Sounds like the there might be a problem on one of the circuit boards.. Its eighter broken solder or a blown ic.. In this case I'd recommend that you have a service technician look at it. We can direct you on the procedure to trouble shoot and repair it, but it will require some knowledge as well as its kinda dangerous for the tv.. YOu will just get a bit of juice but it can result in major damages that will cost a lot to correct. Please contact a local technician it does not have to be a service technician from an authorised dealer.
  • 10,594 Answers
Have you tried to unplug tv from ac outlet for couple of minutes and replug it then powered it up?
please intimate exact model number of tv as it would be written on sticker pasted on rear side.
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Inputs wont work
depending on the model remote and if the remote controls the volume and power, then yes you should be able to..let me know if you need more help or if you have the remote type.
May 04, 2010 | iLO IWT3206 TV
My 32' hd tv wont go from component to any other sorce of input how do i get it to do this
look for the TV/VIDEO button, it should work, check the difforent video options by clicking it
Dec 27, 2009 | iLO 2600 Television
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Ilo 32hd tv from InitialTech
I own an ILO TV that is still under the extended warranty. I've had it repaired twice since May 08 and it has failed again. Since it is still under warranty, I will send it back in to be repaired.... again. If I were you, I'd cut my losses and buy a new TV from any store except Walmart.
Sep 19, 2008 | iLO 3200 32 in. LCD Television
Cannot use the direct tv remote to control the volume, on / off, etc.
I have directTv and an olevia TV, and DirectTV remotes do not support Olevia
Jul 25, 2008 | Televison & Video
Need code
i too went 3months with no remote or codes finally a young tech at walmart in another town told me to use 0171 code but cable guy set me up on cable remote to turn tv on and off tech told me to get a one for all remote 9.99 at walmart and code it but to also push setup code for tvdvd and enter code i use cable remote for tv viewing and the one for all to reach video 2 (press tv/vid button twice) for games and dvd player now i can access menu and use my tv as it should hope this helps
Jan 03, 2008 | iLO 3200 32 in. LCD Television
Ilo 32-hd
ILO TELEVISION TURN ON AND OFF BY IT"S SELF, IF I HOLD DOWN THE VOLUME BOTTON IT COMES ON,LET THE VOLUME BOTTON GO NO PICTURE
Aug 29, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
18 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
