Question about Brother IntelliFax-2820 Laser Fax
Brother Fax 2850 no dial tone
After replacement of the Main PCB in Brother Fax machine model: 2850, it is working but there is no dial coming from speaker and hand set. Can not send or receive any fax. Every thing checked, can you help me out.
    Champion:
  • 320 Answers
Who changed out the main pcb board and why, may be one of the connectors was left of , there is a connector comming from the phone board called the ncu board. go over your connections, or if a service center did the replacement it should have been checked out before you got it back, good luck
Posted on Jan 19, 2009
Cant send fax
Check whether you have dial tone by pressing [hook], if no tone, could be the fax card/PCB needs to be replaced.
Mar 31, 2014 | Brother IntelliFAX 4100 Laser Fax
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Can not sent or get fax,have dial tone but if somedody sent us a fax says line is busy same as when we sent fax dose not go through says poor line,called phone comany they said line is ok,any idea?
Try calling your machine from a telephone...it should answer and you will hear the "fax tones" in the telephone earpiece.
If you do not hear any tones in the earpiece, then this could be an indication that you have lost the "NCU" pcb in the machine...this is the pcb normally that the fax line plugs into in the back of the machine. It will have to be replaced to effect repairs.
Nov 08, 2010 | Brother Office Equipment & Supplies
Cant fax or rec but have line
It would help if you gave make and model...however "generally" if a fax can't send or receive but there is dial tone..what I would do first is call the fax machine from a telephone and see if it attempts to answer( do you get the tones in the earpiece of the calling telephone.??) if not try the machine on another line to eliminate the line...after that you could have an NCU, MODEM or Main PCB fault depending on make and model.
Aug 19, 2010 | Office Equipment & Supplies
Brother 575 phone does not work?
If you can send fax out, your handset should have dial tone. If there is no dial tone, try to replace the handset cord.
Sep 17, 2009 | Brother FAX-575 Plain Paper Thermal
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Cheers
luciana44
Sep 06, 2009 | Brother Office Equipment & Supplies
No Dial tone
Have you had an electric storm or power failure? A power surge can cause no dial tone also. It can be the main PCB in the machine or NCU PCB(board for phone cord). Unplug the machine from the wall, put your finger on the menu key first, plug the machine while holding the menu key, the light will flash and display will say maintenance. Press number 82, if there is a DF error the main board will need to replaced. The main board is the brain of the machine and is one of the most expensive parts of the unit. It is hard to distinguish if it is the modem or the main board on this unit that is causing the unit not to have a dial tone. It may be better to take it to a service center.
Aug 15, 2007 | Brother 2440C Colour Plain Paper Inkjet...
Brother IntelliFax-2820 Laser Fax Logo
208 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
