Question about Lexmark X7350 All-In-One InkJet Printer
Using scanner - Lexmark X7350 All-In-One InkJet Printer
Hi i have the same printer if you have all the software installed right click on the desktop icon and there will be a screen opened up with a preview button on top right hand press that and you should get you picture on the screen then all you need to do is play about till you like the look and scan and print hope this works, or there is a scan button on the printer press that and then do the same
Posted on Dec 27, 2008
Help with scan please
EACH SCANNER IS DIFFERENT. so there is no practical way to help you. Maybe yo should get this documentastion:
How to Use Scanner
Scanners For Dummies 2nd Edition How to Use Computer Scanner Scanning an Image with Scanner
How to Scan Documents
You should do a Google search for Youtube to use your brand of scanner
Oct 01, 2015 | Office Equipment & Supplies
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Can I use my Visioneer 8920 with my new computer that has windows vista?
Yes you can use the Scanner with Vista O/, However you will not be able to use the same software or Icon like you did before in XP
Once you connect the Scanner to Vista O/S, it will install the pre-installed Drivers for this Scanner.
You will have to use Application programs to SCan like MS Paintbrush, or Windows Gallery or Microsoft Image Edition or PICASA etc.
Or you can also open Control panel and click on SCanners and Camera and double click on the Visioneer Scanner to use it.
Visioneer Scanner Drivers/Software for Vista are not yet available from the manufacturers so this is workaroud for you to use your scanner
Jun 29, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
Can 15 volt power adaptor be used on an 18volt scanner?
you dont have other choice, how about to buy an multi plug-in adaptor from 3V up to 23V can manage the voltage of your scanner, but if not this 15volts can support your scanner..
Jun 22, 2009 | HP ScanJet 2300C Flatbed Scanner
Iam trying to scan a document on my flatbed xerox 4800 but it keeps saying please unlock your scanner then it gives me time to do it but i dont know where to unlock it
you might have two program trying to use the scanner at the same time & the scanner is confused.Find out what programs you are using.Hint...even printer programs may use scanner drivers. 2nd.you MUST use the EXACT scanner driver for your scanner. Windows will see the scanner "locked out"
Jan 06, 2009 | Xerox One Touch 2400 Flatbed Scanner
Umax astra 610 p
I just installed this scanner using thenwindow installation but when i double click the scanner it sez that it is not connected to the computer.
Aug 31, 2008 | Umax Astra 610P Flatbed Scanner
Scanner
Do you have any scanner software installed to use your scanner with? In most cases a scanner comes with CD that installs a software package that will allow immediate use of the scanner after installation. Once that package is installed, you place picture in one of the corners of the scanner underneath the lid of course and press either the manual scan button that is on some scanners or the button on the software package that you installed into the computer when first configuring the scanner during installation. I assume you have acquired the scanner as a twain source else little will happen.
Feb 23, 2008 | Computers & Internet
Want umax scanner software
I want a software driver for Umax Astra 2000P Scanner Flatbed Scanner for Windows Xp Operating system.
Dec 29, 2007 | Umax Astra 2000P Scanner Flatbed Scanner
Imageteam IT3800 scanner won't hold the config.
Does the scanner use a small battery to keep the stored information? If it does, this battery might be defective.
Feb 26, 2007 | HHP ImageTeam 3800LT (3800ltp-12) Handheld
Lexmark X7350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
