Question about Maytag MDG3600BW Gas Dryer
After a few heating cycles the burner does not ignite
I actually have a Maytag MDG4000BWW gas dryer. I couldn't find that model listed. After a few heating cycles - igniter glows then burner ignites - the igniter glows but I hear a sound that I can only describe as pouring tacks down a metal drainpipe. The burner doesn't ignite and the igniter shuts off. This behavior is repeated until I let the dryer rest (cool down?). Then the burner will ignite a few times again until I hear this sound. This strange sound starts after I hear the relay click for the igniter. I cleaned the dryer vent and lint filter. Any Ideas? Thanks, Stick87
  • Anonymous Mar 21, 2014
    got clothes out of dryer without actually turning knob to off position. 7 hours later I hear a pinging noise in my laundry room. room was very hot and the top of the dryer was really hot like the top of your stove when you are cooking. It was like the knob was stuck. I unplugged the dryer and let it cool down.
  • Anonymous Mar 30, 2014
    Burner not staying on
  • 5,911 Answers
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Maytag Dryers
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
[http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083]
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
I have a maytag dryer, model # MDG4000BWW. It has...
check the high limit/cycling switch thermostat located on the heat housing ,you will need to remove the front panel to access this,then, bypass the high-limit with a jumper wire and see if the flame stays on longer,if this doesn't help, then check the radiant senser on the tube also they get dirty,you can clean the senser eye or bypass this also and see if its weak,if not then replace the 2 gas coil valves on the gas valve body as these will get weak and shut off the gas supply
May 20, 2010 | Dryers
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Aug 30, 2009 | Maytag MDG3600BW Gas Dryer
Maytag MDG3600BW Gas Dryer Logo
417 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
