Question about Movado Kara 0605248 Wrist Watch
How to remove links?
How do i remove links from a movado kara watch?
5 Suggested Answers
SOURCE: Movado Cronograph - Can't remove pin!
you need to push it thru wit a ling "needle type" toolin order to get it out. it has to be strong enough so that it doesn't bend also because it's quite stuck in there pretty good. thats part of the quality you get from a movado.
Posted on Jul 24, 2009
escapement
  • 2334 Answers
SOURCE: How do I remove links on a Movado elliptica?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
mcdevito75
  • 1970 Answers
SOURCE: remove links on Movado Rondiro #605499 to make the
mcdevito75 here, By the time you recieve the special tool needed to reove the links you can have a small watch repair shop in your area do the job.
Posted on Jul 01, 2010
mcdevito75
  • 1970 Answers
SOURCE: How do I remove a steel link from a Movado
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
Posted on Oct 16, 2010
How can I tell if my movado watch is authentic
  • How to Spot a Fake Movado Watch ' eBay www.ebay.com > ... > Everything Else > Every Other Thing HOW TO SPOT A FAKE Movado or Movado Esquire Watch. Short version: THE ONLY WAY TO SPOT A FAKE IS to have have your local Jeweler or Watch Repair Shop ...
  • How To Spot A Fake Movado Watch ' Made Man www.mademan.com > Tech & Gear > Cool Gadgets > Watches Knowing how to spot a fake Movado watch will help you to make sure you purchase the real thing. Movado watches are ... to spot a fake Movado watch ... Tell You're a ...
  • How to Identify a Real Movado Watch ' eHow www.ehow.com > ... > Men's Fashion > Mens Accessories How to Identify a Real Movado Watch. ... an authentic Movado watch will not contain any such ... How to Identify a Real Movado Watch. ... How to Tell a Real Movado ...
  • Tips to spot a FAKE MOVADO ' eBay www.ebay.com > ... > Watches, Parts & Accessories > Wristwatches Tips to spot a FAKE MOVADO. ... the watches were fake, or the watch is real and the diamonds ... just interested in a watch that can tell time, and looks real at ...
  • How To Tell A Fake? - Watch Freeks www.watchfreeks.com/85-movado/31912-how-tell-fake.html
    • 12 POSTS
    • FIRST POST: 2012-12-17
    2013-01-26 ยท Watch Freeks > Watch Brand Forums > Movado: How To Tell ... to seem real. So my question is:How do you tell a fake from a ... Movado watches can sell ...
  • Authenticity Question - Movado watch forums.watchuseek.com > Forum > Main Forums > Public Forum
    • 8 POSTS
    • FIRST POST: 2008-11-04
    Can you spot any telltale signs of an "impostor" watch? Is this Movado authentic? ... If you call Movado 1800 #, they can only tell ... Authenticity Question - Movado ...
  • Videos too
  • http://www.bing.com/videos/search?q=How+can+I+tell+if+my+movado+watch+is+authentic&FORM=HDRSC3
    Aug 07, 2016 | Movado Watches
    Were do i get links for the Movado Lumeti #0690996?
    Go to http://www.movado.com/customer-service/parts-and-service/ and scroll down to "can I order spare links..."
    You are luck, not many makers who offer such a service, in spite of the obvious need for extra links.
    Feb 09, 2011 | Movado Lumeti 0690996 Watch for Women
    How do I remove a steel link from a Movado wristband 800 series?
    Oct 16, 2010 | Movado 800 Performance watch
    I have a movado watch the serial number is 84 e7 1850 I want 2 know if its real
    As with luxury bags, luxury watch brands such as Movado are copied and sold illegally. Movado watches are popular among both men and women, but sellers of replica watches hurt the brand by providing the buyer with poor craftsmanship. Dealers know what genuine Movado watches look like, and they are familiar with the watch model names and numbering system. While you can take your watch to a dealer to closely inspect its authenticity, you, too, can learn how to tell if your Movado watch is fake by noting a few details.
    Check the material the watch is made of. Replica watches are made of aluminum, and they don't have the same heavy weight of an authentic Movado. Movado watches should feel like quality, solid pieces. True Movado watches are made of stainless steel.Observe the movement of the watch. The movement of the second hand should not be erratic or shaky. It should look smooth as it travels across the face of the watch.
    Look closely for scratches on the glass face. Movado watches are scratch resistant, so any imperfection on the face is a telling sign that it's fake. Hold the face to the light and observe if it gleams like a genuine watch. If it's dull or cloudy, it's not authentic. Also, look for the inscription "Swiss Movado Made" to make sure it's authentic.
    Feel the links and the clasp on the watch. Clasps should feel solid, and the links should be joined together by screws. Gently pull on the clasps and check for any loose pins. If the clasps feel fragile, it's probably fake.
    Jul 16, 2010 | Watches
    Remove links on Movado Rondiro #605499 to make the bracelet smaller
    Jul 01, 2010 | Movado Rondiro 605964 Wrist Watch for...
    Movado Juro watchband. How to shorten
    mcdevito75 here, Best Bet, look for a small watch repair shop imn your area to svae on cost, special tool available on ebay is needed since it's a Movado let the shop remove links to re size.
    Jun 23, 2010 | Movado Juro 0605024 Wrist Watch
    How do I adjust the watch band on a Movado luna model
    If you check my tips here, you will find out how to remove or add links.
    Feb 04, 2010 | Movado Luno 0605635 Watch
    I NEED TO ADD 2 LINKS TO MOVADO WATCHBAND .THE CASEBACK # ON WATCH IS 88.E2.887.2.the #on band is v144.g.2
    An authorized Movado Retailer can order the links for you. you can locate a local retailer on www.movado.com
    http://www.movado.com/FindARetailer.aspx?
    Jan 21, 2009 | Watches
    Jan 26, 2008 | Movado Kardelo 0605479 Wrist Watch
    Movado Kara 0605248 Wrist Watch Logo
    65 people viewed this question
    Top Movado Watches Experts
    Marvin
    Marvin
    Are you a Movado Watch Expert? Answer questions, earn points and help others
