Question about Motorola Mobility RAZR V3
Razr v3 flex cable repair
I was wondering if you do this for a living...if so...how much do you charge to replace the right(when looking at the back of the phone with the battery removed) flex cable?
    Brigadier General:
  • 7,752 Answers
Yes most of us do this for a living...it depends on the person or shop you go to.
Posted on Dec 28, 2008
Razr V3
i think the cable/flex is not compatible with your phone..
razor v3 flex is different from the flex cable of v3i..
wich one is yours?
Aug 30, 2008 | Motorola Mobility RAZR V3
Razr v3 flex cable connected but screen is still black
You can buy a new phone.....but I had the same exact problem with my motorola v3 phone. Every now and then both screens would work for a while and then turn completely black or sometimes white. Most of the time black. The keypads would light, I could make and receive phone calls, but I couldn't see anything on either screen. I moved all my contacts to the sim card and I got a new phone thru an upgrade with my company. But I was still determined to get the V3 to work again! I brought the phone to a few cell phone repairs shops and I was told that the connectors from the flex cable inside the phone sometimes get loose. Make sure they are tightly plugged in. If that doesn't help then the flex cable needs to be replaced. Some of these repair shops wanted up to $65.00 to replace the flex cable! I could replace the phone for much less than $65.00! So I decided to go to ebay and type in Motorola V3 Flex cable......hundreds of places came up that sell this flex cable. I found a place in my area and ordered one. It cost me $5.00 and I got it within 2 days! I looked online on how to install the flex cable and everything from how to disassemble the phone to installing the new flex cable and reassembling the phone was right there! I followed the instructions and I installed the new flex cable and the phone is as good as new!!! Both screens are working and I didn't loose any pictures or contacts from the phone!
All it cost me was $5.00 and about an hour of time! It even came with free shipping! Go to google and type in Motorola v3 black screen and look thru the solutions. Some of them will explain how to disassembe the phone and replace the flex cable with detailed pictures! You can buy the torque screw drivers at Home Depot or on ebay! Good Luck!
Jul 15, 2008 | Motorola Mobility RAZR V3
Motorola razr
Most likely the small flex cable on the LCD screen in the top part of the phone needs replaced. The speaker in the earpiece must be bad and it is soldered to this flex cable. It can be repaired by a cell phone repairman.
May 30, 2008 | Motorola Mobility RAZR V3
RAZOR V3
it shows that you are having flex cable issues - common problem with the v3. you would have to bring it to a local repair shop or order a keypad flex and button flex cable to do yourself.
the parts are about $15-40 and a shop will charge about $25 to install
if all else fails contact me and we can help arrange it.
Feb 01, 2008 | Motorola Mobility RAZR V3
New razr v3
you need to have the flex cable replace...take the phone to a professional mobile repair center and have the techs replace it for you.
Dec 26, 2007 | Motorola Mobility RAZR V3
Light for keys wont work
do a master clear and reset if that does not work, then you have to replaced the flex cable.
Dec 24, 2007 | Motorola Mobility RAZR V3
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
V3 razr
you have a software problem...
have your phone reprogrammed to a trusted repair shop or probably their a problem in the flex connector..
Oct 18, 2007 | Motorola Mobility RAZR V3
Razr v3
To solve this you need to clean up the flex cable in the screen.To do this u need 2 take your phone to an authorised phone repair person to get it done. If this doesn't work to need 2 replace the main flex cable. Sam !
Sep 19, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola RAZR V3 LCD SCREEN went blank - black screen
The LCD flex connector is very sensitive. 4/5 of the RAZR screens I see go out are due to a loose flex connection. It's super easy to fix it. Take off the battery door. There are two T6 screws. Take them out and pop off the bottom of the phone. There are two flex cables: one for the keypad, the other for the screen. Connect the flat cable (screen cable) first. Then connect the bent (keypad) cable. Put back together. Voila.
Aug 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
