Question about Guillemot 3D Prophet 9200 (128 MB) Graphic Card
I have a problem using a screen in a high solution using mine 3 d prophet 9200 graphic board. The new screen I got is a 22 wide flat screen. Can the problem be the graphic card? What is the solution for that?
  • klaudiuszw Dec 29, 2008
    Thank you very much, I downloaded the newest update and now its working really well with the best resolution.
  • 24 Answers
The 9200 is not the most powerful card for running what I assume would be a 1680 x 1050 resolution for your 22 in monitor. It should be ok for email, surfing the web etc, but it will probably struggle badly with any kind of intense 3d activity such as gaming or CAD work. I would suggest turning the resolution down to 1280 x 1024 or lower, or upgrading your graphics card to a more powerful one. Sorry, I'm sure that's not what you wanted to hear...
Posted on Dec 25, 2008
How do you enable onboard video card in bios
Here's what others have tried.
I like the jumper and cmos and enable/disable portions
avatar-default.png Posted bylesleymillar on 11 Oct 2009 8:00 AM Just fitted a new PCI graphics card (Radeon 9200) in my 4 year old Dimension 2400. The only way I can get it to work is to have both it and the on-board graphics chip running together - done this by selecting the Radeon as the default display and by not having the Windows desktop run over onto the Intel display. Problem: If I disable the on-board graphics chip as per the fitting instructions and then set my Bios to auto select, the computer boots and is active but all I get is a blank screen regardless of which output the monitor is connected to. Also, as I have the Radeon as the default display in Windows I don't see anything (no Dell boot screen, etc) when I switch my machine on until Windows log on screen as I have to have the Bios set to 'On-board' in the graphics option otherwise the aforementioned problem persists. Has anyone else encountered this problem, and if yes, has anyone managed to overcome it i.e. successfully disabled the on-board chip? Unfortunately there is no Bios upgrade from Dell that allows a user to select either auto, on-board AND PCI - the last one being ideal it would seem!
{count}" data-configuration="Format=%3Cspan%20class%3D%22count%22%3E%3Cspan%20class%3D%22icon%22%3E%3C%2Fspan%3E%7Bcount%7D%3C%2Fspan%3E">0
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 4:58 PMI just configured a 2350 with a PCI card (Sparkle 8400GS), and I left the BIOS setting at auto-select. (I could find no way to disable the onboard graphics.)
    I found that if Windows installed a driver for the onboard graphics before the PCI video, the onboard graphics were used for the default monitor. Thus, I got no image from the PCI video. I connected a second cable to a spare DSUB port on the monitor to the onboard graphics and switched inputs until I got video. Then I downloaded the appropriate video driver for the onboard graphics, installed, and rebooted. Upon reboot, I switched the default monitor from the onboard graphics to the PCI video, after which I could remove the second video cable.
    Hope that helps!
  • 4tjv4usnef6m.jpg-32x32.jpg?m=634535492957260780 Posted byJackShack on 11 Oct 2009 6:32 PMSome additional information that may be helpful:
    1. The Dimension 2400 uses an on-board AGP graphics chip that cannot be disabled in hardware. It shares the interrupt for the first PCI slot which can give you trouble if you decide to place your add-on PCI graphics card in slot 1. My own add-on card wound up in slot 3, so it might be helpful to switch to another slot before giving up.
    2. If you do have your card in slot 1, try resetting the NVRAM (CMOS) by removing the battery for about five minutes. You can find instructions for that here: Dimension 2400 Service Manual. Look in the section on Removing and Installing Parts, Battery. While the battery is out and everything still unplugged, push the power button and hold it in for about fifteen seconds to ensure the discharge of any storage elements. When you put the battery back in its holder and fire everything up again, the computer will take a new inventory of its devices and will sometimes finally find the PCI video card.
    3. This next you've probably seen, but it bears repeating: Before attempting to install the new card, go to the Device Manager, Display Devices, and find the Intel Graphics Adapter. Double click it to bring up its properties, go to the bottom of the little window to Device Usage, and click the small arrow on the right to get the menu. Select "Do Not Use This Device - Disable". This will disable the onboard driver and cause the computer to load the standard VGA driver that works with all the video cards. Sometimes the reason you see nothing on the add-on card is that Windows is still trying to use the driver for its previous video adapter which is incompatible with the new card.
    Dell Forum member since 2005
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 7:40 PMIt might help to disable the onboard video in Vista, as ATI drivers can clash with it and cause BSODs. Under XP it'll co-exist.
    There is a jumper on the mainboard for clearing the CMOS. It is marked as such, and the manual will point it out.
    The default Windows driver for the add-on card will work, but without acceleration and with a very low resolution. Also, if Windows installs the driver for the onboard graphics first, it will mark the onboard graphics as the primary display.
  • 4tjv4usnef6m.jpg-32x32.jpg?m=634535492957260780 Posted byJackShack on 11 Oct 2009 9:10 PMYes, I neglected to mention that if you get the card to work in the VGA mode you should be able to install the specific driver for the card. In the past I have recommended that no attempt be made to load the driver for the card until a VGA screen can be displayed.
    Granted there is usually no conflict if the onboard driver is left in place; the problem arises when the BIOS sort of recognizes the new card but for some reason Windows fails to find a driver for it. In this situation you get video from neither the onboard port or the PCI video card port. This seems to happen a lot if the card is installed into slot 1. In the past I've corresponded with folks who seem to be able to get the card to work only by using the Windows multi-monitor capability; extending the screen onto the video card. The only irritation with this is that you get no video until Windows loads, so if you want to see the system setup screen you need to switch ports.
    Naturally I realize that a jumper is there and is supposed to work, but removing the back-up cell makes certain that the NVRAM will be cleared.
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 10:40 PMThe jumper definitely works, as I used it last week several times in dealing with a recalcitrant 2350.
    Windows should find a driver for any VGA-compatible card; it'll be a default VGA driver. However, if Windows can find the driver for the onboard video, it will use that as the primary video, regardless if they are connected or not, and the user will get no video from the PCI card. I had this problem with the 2350, and had to temporarily install a VGA cable to connect the onboard video; after installing the drivers for the PCI card, I'd switch the primary monitor to it and all would be fine.
    When I installed Vista on the 2350, I experienced BSODs on startup until I disabled the onboard video. I am not sure if this happens with nVidia cards as well as ATI ones.
    I tried two cards with the 2350: an expensive HIS 4350 ATI and a much cheaper Sparkle 8400GS. The 4350 worked, but did not accelerate video playback (ATI said they did not support it over the PCI bus), so I RMA'ed it. The 8400GS installed without incident and worked perfectly and accelerates both standard and high-def video. Both cards were installed in slot 3.
Jun 01, 2014 | Dell Dimension 2400 PC Desktop
I bought a samsung BX2231 LED monitor in November, 2010 I am trying to connect a HDMI connection and trying to give audio into the speakers, but am unable to get any audio from the monitor to speakers....
Ii there,
if I understand you correctly you are connecting a pc/laptop to your screen and want to use the screen speakers.
On a laptop I would be surpirised if it doesn't auto setup the connection so maybe check the graphics property settings to see if there is anything obvious.
If this is the case, then most pc add-on graphics cards will require a connection to the audio device on the pc.
If you have an on-board audio device then look around the mainboard for a 2-3 pin connection labelled spdif, this is the connection you require. There should be a similar small connection on your graphics card.
You will need a small cable which you should be able to pick up at most pc shops and should be quite cheap. Once this is fitted restart the machine and see if you have sound from your screen. If not then there may be a setting in the graphics card software to set the audio (Mine is in the nvidia control panel and connection type is hdtv/audio enabled)
Hopefully this has been of some help.
May 07, 2011 | Samsung BX2231 22" LCD TV
Im using a flat panel monitor conected via hdmi cable, and the screen goes black occasionly
From your question it seems that there is some fault in your hdmi cable try to change it.
For any other help or to thank me Mail on my email Ejaz89@live.com
Jul 28, 2010 | ATI RADEON 9200 Graphic Card
No video output..require advice for best plug and play video card
The on board graphics are 4:3 screen size and I'#ve
just purchased a 22" wide screen and cannot obatain
1680 x 1050.
Oct 22, 2009 | ASUS K8V-MX Motherboard
I just installed SIMS 3, and it keeps freezing up and crashing. Is my ATI Radeon X600 the problem?
The card is most likely NOt the problem, best thing to do is upgrade the Graphics drivers and other drivers... If that doesnt work...
Check to make sure the Ram is sufficient,
I believe it would be the problem if its a older card, and Sims 3 is a high Polygon game. and Alot of radeon cards Get old quick.. if You really want to play sims 3 Upgrade your Video Card If your running a Crossfire Mother board (Ati only) Buy one of the new Ati cards 4890 i believe is the newest one, Its a great card
If your running a Full compatibility board buy one of the new Nvidia's But before you buy make sure your Computer Supports it :)
Jun 04, 2009 | ATI RADEON 9200, (128 MB) AGP Graphic Card
Require graphic card for ASUS K8V-MX
DOWNLOAD FROM HERE......
http://downloads.viaarena.com/drivers/video/ProSavage/139365IShld.zip
Apr 06, 2009 | ASUS K8V-MX Motherboard
Cannot play FIFA09
Uh oh. It looks like you're out of luck.
FIFA 09 PC Requirement (minimum):
Graphics: 6600 Nvidia graphics card or ATI equivalent with support for Pixel Shader 3
DirectX Version: DirectX 9.0c"
Nvidia 6600 came out at 2004 and it supports DirectX 9.0C (Shader 3 came with 9.0C)
ATI Radeon 9200 came out at 2003 and only support DirectX 8.1 (which support shader 1.2 - 1.4)
Nope, Radeon 9200 will not support Shader 3 (neither will it support 2.0).
Time for a new video card maybe?
I hope this answers your question.
Mar 16, 2009 | ATI RADEON 9200SE Graphic Card
Monitor going going gone
Presario X1000 has 3 different ATI graphics boards they use.
Two are 32mb and one is 64mb.
For use with HP Compaq nx7000 and
Compaq Presario X1000 notebooks spare part#
ATI MOBILITY RADEON 9200 w/64-MB memory 336970-001
ATI MOBILITY RADEON 9200 w/ 32-MB memory 336969-001
ATI MOBILITY RADEON 7500 w/ 32-MB memory 336968-001
I have on PDF the service repair manual, I can e-mail it to you or you could try to google it.
Apr 28, 2008 | Compaq Presario X1000 Notebook
Hopefully a graphics problem.
Dell is offering to replace the LCD on the Inspiron 9200 within 3 yrs of purchase under recall for free. You must talk to a supervisor because most of the "others" have no clue. Hope this helps. I replace mine, my wifes and my sisters under this program.
Jan 07, 2008 | Dell Inspiron 9200 Notebook
Hercules 3d prophet II max
The current generation of games will not play well (if even at all) on this graphics card.
Nov 28, 2007 | Guillemot Hercules 3D Prophet II MX (32...
Guillemot 3D Prophet 9200 (128 MB) Graphic Card Logo
199 people viewed this question
Top Guillemot Computers & Internet Experts
micky dee
Maxx
Level 1 Expert
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Guillemot Computer and Internet Expert? Answer questions, earn points and help others
