Question about Samsung 1200W 5.1-Ch. XM-Ready Home Theater System with Upconvert DVD Player
Can only get the dvd player to use the surrond system
The dvd will work with the surrond but I also have direct tv satt. and regular cable and can't get them to use the home theater sound
  • 8,596 Answers
This is going to be a bit tricky with this model, since either your Cable or Sat box will need a Digital Audio Out, and you will need to purchase a Digital Audio cable. If your sat box has a digital audio out, connect a digital audio cable from the sat box to the digital audio in on the back of the Samsung. Then connect a red and white AV composite cable from an available audio out on the back of the cable box to the "Aux In 2" on the back of the Samsung - this may only allow stereo sound, however.
Your absolute best bet (and the simplest connection) will depend on whether your TV has a SPDIF OUT or Digital Audio Out (they are roughly the same). If your TV has a Digital Audio out, connect a digital audio cable from the TV to the Digital Audio IN of the Samsung. Now you will get sound from any cable, sat, or any other type of box that is connected to your TV.
-Tha Mp3 Doctor
Posted on Feb 11, 2009
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
How to connect an Xbox 360 to an RCA RTD205 System?
you can turn every thing into surrond sound. all your visual componants, i.e. x-box, cable, dvd player and so on. connect directly to your tv, right? if so go to your local eltronics store and get youself an optical cable, typically $50.00 or so depends on the length. Go home with that cable connect it to the optical out on your tv and optical in on your reciever, (stereo) and bam all componants are now linked to your surroun sound. Dont forget to post your satisfaction. Be sure you have optical in and out before you go buy this wire. For god sake do not kink this wire either or you will have to buy a new. There is glass inside of optical wires, that transmits the light that the sound travels on.
Feb 25, 2010 | RCA RTD205 System
Want to use Panasonic SA-HT740 for TV sound
Get the TV audio from the Dish box directly to the receiver.
Feb 16, 2010 | Audio Players & Recorders
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
LG LFD790: surrond sound only DVD mode?
go to the DVD screen and hit home button, scrool to the "EZ" icon and it will say AUX or OPTICAL. Chose OPTICAL and swich back to cable and you should have sound. This will work, and no the manuel does not tell you this and most techs have no idea. Best luck
Aug 28, 2009 | LG LFD790 System
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
I have LG dvd player connected to 5.1 home theatre system with 5 speakers......But only 2 speakers are working...theres no problem with home theatre, it works with all speakers when connectd to...
Please check the menu and enable 5.1 surrond option on and the dvd player dose it support surround if yes also check that u have connected the correct colour cable in correct palces..
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
-samsung dvd cinema surrond system ht-x715t htk makes loud buzing sound when switched on. - need a code to programme sky remote control for samsung lcd tv le40a656a
good day
try looking for loose connections in your speaker cable as well as its connection through its terminals, there might be some loose connection somewhere which causes some grounding on your system. you can also try to reattach your speaker system.
i hope this helps
Oct 09, 2008 | Samsung Televison & Video
Problem hooking up my system to the T.V.
check the back of you tv and see if it has the audio out plugs. if it does the you plug the white and red audio cables into the audio (in) on the dvd player and the audio (out) on your tv. then press function on your dvd player until the light on a/v comes on.
Jan 04, 2008 | Durabrand STS92 System
Samsung 1200W 5.1-Ch. XM-Ready Home Theater System with Upconvert DVD Player Logo
249 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
