Question about Maytag EPIC MFW9700S Front Load Washer
F20 code We can not find our manual, can you tell me what the f20 error is and how to fix it
  • LindaConnor Jan 19, 2009
    Washer won't fill (it's brand new (only used since September). Flashes the F20 code. HELP!!
  • mithan Jan 22, 2009
    what is F20 and how to fix it?
Its water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Posted on Mar 16, 2009
  • Kimberly Lynch
    Kimberly Lynch Sep 10, 2012
    awe thanx for that info Deleonx ... i thought that might be the problem but what if it is flashing f11 what is that one
How do I fix error code f20
To remove the f20 error code from the display panel, press Pause/Cancel 2 times.
Jun 28, 2017 | Washing Machines
Fisher & paykel refrigerator RF195A
Hello!
Error F20 - it often means that the light bulb of the refrigerating chamber burned down. You need to replace it.
Here is also a link to the manual.
http://manualsbrain.com/en/manuals/1295058/?page=43
Hopefully, it will help you!
May 16, 2017 | Fisher Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How to fix F20 error code whirlpool duet
How to fix F20 error code whirlpool duet YouTube
https://www.youtube.com/results?search_query=How+to+fix+F20+error+code+whirlpool+duet
Sep 04, 2014 | Whirlpool Washing Machines
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20 error
F20 is a door lock problem. Try resetting the breaker. if the code comes back replace the door lock.
The first thing I would check is the door lock switches and the wire harness.
Here are the break down diagrams for the Frigidaire range Model PLES389ECB
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
1,226 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
