Question about Dell Dimension 4550 PC Desktop
Power saving options don't work
I set the monitor to turn off after 3 minutes and the hard drive to turn off after 5 but nothing happens. The numbers above are just examples no different times work either.
  • chris dowell May 11, 2010
    How are you sure that these do not work will your monitor not turn off ?
    Scholar:
  • 170 Answers
There might be something like " dell power settings/plan " in your control panel that are over ruling the settings that your adjusting
Posted on Dec 27, 2008
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
Tip
How to make your Laptop Battery last longer
1. Turn off Wi-Fi and BlueTooth - Most laptops have shortcut keys to instantly disable wireless networking. <br /> 2. Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries. <br /> 3. Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse. <br /> 4. Adjust your screen brightness - Dimming your display saves battery power. <br /> 5. Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity. <br /> 6. Decrease or mute the Laptop Speaker Volume. <br /> 7. Turn off all scheduled tasks. <br /> 8. Turn off Auto-save features in Microsoft Office and other applications. <br /> 9. If your PC has a built-in wireless card, turn it off or disable it when not in use. <br /> 10. Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
on Dec 27, 2010 | Computers & Internet
Tip
Is your hard drive or monitor randomly switching off after a few minutes of...
This problem could be that your Power Options in the Control Panel have been switched to "switch off the component ever now and then to save power". To change this, do the following:
1) Navigate to the Control Panel by clicking Start and then Control Panel. Then double click on Power Options as shown below circled in red.
2) This will then display the Power Options window as shown below.
3) Once you have opened the Power Option Properties, under Power Schemes select the one that best suits your PC system.
4) Then you can select whether or not to switch off your monitor and/or hard drives after a period of time when it is not being used.
If you have your PC on most of the time then I suggest you select Never as the turn off option for both your hard drive and monitor. If you are using a laptop the turning off the hard drive and screen can however save on battery power when the laptop is not in use.
If your problem persists then it might just be as simple as a loose connection, make sure all hard drive connectors are firmly inserted and that your monitor display plug is correctly plugged into your display card or onboard display correctly.
If your hard drive persists with this problem then it may be a faulty dive. I suggest you take the drive to a PC technician and have them check if it's faulty or malfunctioning.
If you can faintly see your desktop background on the monitor that switches off then check my tip about LCD backlighting issues: http://www.fixya.com/support/r6836567-lcd_monitor_displays_background_fine
You can also check out my video tutorial on this below:
on Nov 13, 2010 | Computers & Internet
I entered the problem before. Here it is again:
In the Control Panel>Accessibility>Display
If the high contrast box is checked, uncheck it.
When you say in "Add program", where is that exactly? Under Display in the Accessibility window I only see High Contrast Options andCursor Options. Did you maybe change a program in the Control Panels "Add or Remove Programs" section? It's either that
or
your monitor may be entering power saving mode.
If your problem persists then it might just be as simple as a loose connection, make sure that your monitor display plug is correctly plugged into your display card or onboard display correctly.
Let me know how it goes.
~Slasher_X
Nov 06, 2011 | Computers & Internet
Somehow I must have done a 'Setting-Mistake' , as my LG monitor ( MS xp ) switches for 3 seconds completely black, in regular sequences of 1 minute. Please help Hans
Hi there.
or
~Slasher_X
Nov 06, 2011 | LG 22" FLATRON LCD Monitor
My computer works normally but my monitor suddenly turns dark. I try to turn off the power (monitor) and when I turn it on back, it turns to normal. but few minutes later, the problem goes back. This...
Sir,
Does this happen when you leave your computer idle for few minutes? If so,then the Pc is
simply turning off your monitor to save power when you don't use it.And you can turn it back
on simple by hitting keys on your keyboard or moving the mouse to and fro.However if you
would like to disable/change this option the please do the following.
If you are using Win XP,then
1.Click the windows Start button,then click Control Panel,click Performance And Maintanance
and then click Power Options.
From the window that opens,choose the time period after which you would like your monitor to
get into power saving mode (the default is 5 mins) or choose 'Never' from the drop down box
next to where it says 'Turn off monitor'.Then click the apply button and finally the ok button.
If you are using Win 7 or Vitsa,the please follow the following link to learn how to disable this option.
http://www.howtogeek.com/howto/windows-vista/disable-power-management-on-windows-vista/
Oct 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
    5. Then you will see the Safe Mode menu.
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Oct 04, 2009 | Sony Video Game Consoles & Games
    Monitor goes to sleep after 30 minutes vl1919
    Welcome to FixYa! The default power saving feature is turning the monitor off. To change the settings go to the Desktop>Right click on it>Properties>Settings and you will see power saving settings where you can choose "Never turn off" or a longer time interval. These settings can also be found in your Control Panel for all of the Power Saving features for the computer, monitor and hard drive. Steve
    Jan 03, 2009 | Princeton Digital VL1916 19" LCD Monitor
    Problem with video card, only show compaq screen
    First connect llaptop to another monitor and open this pics!Display Settings have to be like in this pics and i hope it will help u...
    http://img442.imageshack.us/img442/4357/videocardrh4.jpg
    http://img442.imageshack.us/my.php?image=videocardrh4.jpg
    Oct 11, 2007 | HP Compaq Evo n610c Notebook
    Analog Power Saving Mode
    Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
    Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
    Dell Dimension 4550 PC Desktop Logo
    52 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
