Question about Polaroid i733LP Digital Camera
Polaroid i737 doesn't have a setup menu
I have a Polaroid i737.  Using the Setup menu is the key to everything, but the Setup menu icon does not appear.  This causes all kinds of annoying problems, for example the camera is stuck in the German language right now, and the only way to change this is by accessing the setup menu.  Another example, I can't "reset" the camera to default settings, which would seem to solve all these problems, without the Setup menu.
The camera was "Q-Mode", which causes only an abbreviated menu to appear.  By taking the camera out of Q-Mode, which is done on an entirely different menu and not made clear at all in the owner's manual, the Setup menu is available.  The Setup menu is the key to everything in this camera, so my advice is to not keep the camera in Q-Mode.
Posted on Dec 26, 2008
How do I put batteries in camera i737?
If you mean the Polaroid i737, see the illustrated instructions on page 8 of the manual: http://www.camera-usermanual.com/manuals/polaroid/Polaroid_i737.pdf
Sep 14, 2014 | Cameras
Problem on polaroid 04011c not shoving menu display or volume or eny command
Does your set respond to the controls on the set itself?
If you, are you able to access the setup menu to perform a factory reset?
If so, press menu, navigate over to setup, then choose reset defaults, to see if that improves your situation.
I hope that helps.
_________________________________________
Polaroid TLA-04011C Manual Download
Polaroid TLA-04011C Service Manual Download
Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Card error
The internal memory is very small, so that is normal. Make sure the switch on the card is set to unlocked. Also, if the card is over 2GB, it is not compatible with this model, you'll have to try another one. Make sure the card is inserted correctly and that it clicks into place. Verify on the camera screen by checking for a picture of a memory card just under the battery icon. If it says IN, the camera is not reading the card.
If nothing else works, backup your photos and format the card. This will erase all data on the card. You can format the card from the setup menu. (Menu > Setup [Wrench icon] > Format > Yes) Make sure not to use the card with other devices at the same time, it may leave data on the card that the camera cannot read properly.
If none of this helps, see if the camera works without any card. If it does, then the card may be defective, try another one (noting above size limitations).
Jul 31, 2009 | Polaroid i737 Digital Camera
Polaroid i737 usb cord
I was in need of a new USB cord for my Polaroid i737 as well. This was a problem for me because thee SD card I use with my i737 is a HC card and can only be read by/through my camera. Thankfully, I managed to find one on E-bay and purchased it.
However, if you are using a non-HC SD card for your camera, I would suggest just using an SD card reader to transfer your photos from your card to your computer.
Jun 23, 2009 | Polaroid i737 Digital Camera
Icant download pictures from my polaroid i737 camera to vista
go to the file on your camera where you know the pictures are and drag and drop or copy and paste all the pictures into a folder you put on your desktop or where ever you want it.
Feb 23, 2009 | Polaroid i737 Digital Camera
Polaroid i737 battery usage
Change the battery type in the Setup menu to NiMH.
Feb 02, 2009 | Polaroid i733LP Digital Camera
Polaroid i737 power problem
buy rechargable batteries atleast 1800 mhz..goes upto 2800mhz..
should solve problem
Dec 25, 2008 | Polaroid i737 Digital Camera
Cannot access PREFERENCE SETUP menu to reset to default settings
Remove disk from teh disk tray and try Setup after that.
Nov 01, 2008 | Amphion Mediaworks T-365 System
Polaroid LCD has Flourescent Lights and a Blurry Screen
okay I just got mine to work. All I did was: click menu on my remote control, go to setup, go to the very bottom where it says "Default" and press ok on the remote. Everything went back to the default settings and worked.
If the audio still doesnt work, go to menu, audio tab, down to MTS system and hit right or left on the remote to change the audio setup.
Oct 26, 2008 | Polaroid FLM-3732 Television
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Polaroid i733LP Digital Camera Logo
171 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
