Televison & Video Logo
Posted on Dec 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi VS-5075 inputs only show input 1 not 2 or 3
Trying to hook up xbox360 to the front inputs (3) changing inputs only shows input 1 not 2 or 3. even in the rename inputs menu it only show input 1 not 2 or 3. how do i get all 3 inputs to show on menu?
Anonymous
Level 3:
  • Master 365 Answers
  • Posted on Dec 25, 2008
Anonymous
Master
Level 3:
Answers
365
Questions
Helped
110910
Points
1004
First you select and store the input 1 and then change the input name as 2 and store it,then do the same for the third.now you have saved the all and i think you can get the all shown in the menu.thank you
Anonymous
Level 3:
  • Master 10,594 Answers
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955193
Points
33084
Press reset button (tinny) on front of tv at left corner. TV light will blink approx 1 minute and power up tv again. Input1, 2 and 3 will be in menu.
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
1helpful
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
1helpful
2answers
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
2helpful
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
2helpful
2answers
62' DLP WD-62525
Since the set turns on and displays this message we can asume the set is working, so for the next step simply change inputs and see if something comes up, either there is nothing hooked to input 1 or the device hooked to input 1 is off or has failed
Set-up
the set should have it's own tuner hook cable to ant and then select ant from remote input
2answers
Pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
8helpful
3answers
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
