Question about Toshiba 32A33 32" TV
Toshiba television the port that the cable (75 ohm) screws into broke off. What can I do about it?
  • Anonymous Jan 22, 2009
    NEED PASSCODE
    Sergeant:
    Champion:
  • 346 Answers
It can be repaired .other wise you would have to replace the tuner
Posted on Jan 13, 2009
My wii u stil wont work after being hooked to an rf modulator to an older tv
Hi Lisa can you provide some more information
What is the model number and make of the rf modulator?
what wii output did you use to go into the rf modulator ?
what frequency does the rf modulator output at ?
What model number and make is the television ?
What type of cable is being used from the rf modulator to the tv ?
Is it a video cable or a proper 75 ohm impedance coaxial cable
what is the impedance of the rf modulator output is it 75 omhs and what is the impedance of the tv is it 75 ohms or is it 300 ohms if it is 300 ohms on the television ( usually antenna is a ribbon cable screwed onto the back of the tv rather than a coaxial socket ) different you need a balun
http://www.jaycar.com.au/productView.asp?ID=LT3022
I am recommending your first point of problem trouble shooting first is to check the impedance of your television compared to the impedance of the rf modulator and compared to the impedance of the cable used. IF they do not match then power is lost and the signal won't get to the TV.
Dec 27, 2014 | Nintendo Wii U
Antenna cable missing for Panasonic sa-pm42 stereo
782d9ae8-52f7-4cc4-a661-56731bddb11f.pnge94ad7da-0a4e-4d24-aacd-af1ae2881119.png980b7cad-16b3-4152-9d9b-f008ef27d842.pngThere are two types 300 ohm and 75 ohm. Some amps have both types of connection.
The 75 ohm type use plugs and cables commonly used for TV aerials and Satellite dishes.
The 300 ohm type uses screw clip terminals where you attach a coloured cable.
All shown here: The FM socket with the thread on, uses a Satellite connector plug.
May 28, 2013 | Audio Players & Recorders
Cannot find where to connect aerial lead into tv
If set has a coax or cable fitting and antenna lead is flat wire you need a adapter---flat wire is usually 300 ohms and the coax is 75 ohms, the adapter in that case will allow you to attach the flat wire to screws on it and then slide the other end onto the cable fitting.
Dec 22, 2012 | Televison & Video
Curtis RT068 antenna
if a coax fitting used on the set 75 ohms, screws are 300.
Mar 29, 2012 | Curtis RT068 5 in. Portable Television
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
Where can I find an antenna for this unit?
External FM antennas can be had for as little as $7 for the a simple dipole version (looks like a "T") to a highly directional outdoor type for over $150 at your local Radio Shack below:
http://www.radioshack.com/search/index.jsp?kw=fm&f=Taxonomy/RSK/2032189&categoryId=2032189&kwCatId=2032057&fbc=1&filterName=Category&fbn=Taxonomy/Antennas
The simple $7 dipole is a "twin lead" 300 ohm type that many home stereos shipped with because they are inexpensive, take up little room in the box and work surprisingly well for all but the very distant of stations. These antennas are also found for sale in many department and some hardware stores too. Your stereo may not offer twin lead or 300 ohm hook ups (2 terminal screws near the ANT label) but only a 75 ohm connection (like your cable tv connections), in which case, you'll need an inexpensive 300 to 75 (terminal to cable) ohm balun (or matching transformer) like this one below:
http://www.amazon.com/Parts-Express-Push-On-Balun/dp/B0002ZPIOQ
or to go the other way - from 75 to 300 (cable to terminal) ohm balun like this one:
http://www.amazon.com/75-300-Ohm-Matching-Transformer/dp/B0002ZPIOG/ref=pd_bxgy_e_text_c
Please rate this reply if you found it helpful. Good luck!
Jul 01, 2010 | Philips FW-D5 CD Shelf System
How do I hook up a digital to analog converter box to my 13" phillips TV/VCR COMBO. It does not have an antenna on TV
There should be a cable connector on the back of the TV.
If there are two VHF screws instead you will need to buy a unit from Radio Shack called a 300 ohm to 75 ohm transformer.
Jun 29, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
Cable?
since the DGL20 uses a PAL connector, you will need an adapter plug from PAL male-to-RF male (75 Ohm) connector. You can also try a RCA male to RF male (75 Ohm)
May 12, 2009 | Digimate DGL20 Television
Do I have Progressive Scan on my TV?
component video is HD of sorts lower end of the scale. Your set has progressive scan..
Mar 26, 2009 | Televison & Video
Tv is not cable ready
You need to buy a cable output to television antenna input adaptor. One end will allow you to connect the cable box output to a cable input. The other end will hook up to you television just like a antenna, on the two screw hook -up. The usually can be purchased at any electronics store, like Fry's, Best buy,Radio Shack. Or you can buy them online. Use google to search cable output to television input adaptor's. Hope this helps you with your problem.
Nov 28, 2008 | TruTech PLV16320 Television
Toshiba 32A33 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
