Question about Durabrand DWT1304 13" TV
Video input lost
Cable man hooked cable to the tv to test the line. Now I can not get it to work with video input. I do not have the manual or remote.
  • 1 more comment
  • basilkey Dec 25, 2008
    Think I found the answer. 3 in 1 remote at radio shack.
  • Anonymous Jan 04, 2009
    lost inputs
  • Anonymous Apr 09, 2009
    is there any way to switch the video input WITHOUT the remote for this tv?
  • 379 Answers
just in case you need the manual. thanks.
Posted on Dec 30, 2008
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
The remote accidently has S video button pushed. I have S Video at the top of a blck TV screen. I'm not sure how to get back to the TV screen because no button is working. I run the TV through the...
Use your TV remote to change the input away from S Video. There should be an Input button or Video Source button. Press this button repeatedly to cycle through the inputs. Depending on how your cable box is hooked up to your tv, your input will vary.
Jul 18, 2011 | Vivitek Televison & Video
I can't figure out how to program cable box. The cable is hooked up to the TV, but I can't find out how to get channels. Is there a certain menu or imput?
Are you getting any picture at all? check your tv's input button on the remote if your cable box is hooked up with hdmi select hdmi, if it is component video cable select component video, and if it uses a coaxial cable it should be something along the lines of tv. Push the input button on the remote to switch between the different modes
Mar 20, 2011 | JVC HD-56FN97 56" Television
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD cables
You have to plug your DVD cables into the "input" connectors on your tv. Input audio and input video. Also there is either a switch on the back of your tv or in your menu where you have to choose "component video". Or it might be labled Video 1, Video 2, Video 3, etc. You might have both a switch on your TV and a choice in your menu. If so, both have to be set to "component Video. Sometimes on the back of your set, the switch is not labeled. It just has "arrowed" lines coming from the different switch positions and leading to the "outputs and inputs" on the back of the set. Set the switch so that the lines lead to the red, blue and green INPUTS on the back of your set. Your problem is not serious. It is just a matter of "telling" your TV that you are using "component video". Component video is when you are using the red, blue, and green inputs. It is also possible that your DVD has another output besides "component out" and also has a switch. Make sure this switch on the back of your DVD is in the "component OUT" position. Your DVD might also have a connector on the back that looks like connectors on the back of VCR's and most TVs. This is an "F" connector and the cable has to be screwed on. It's just like a cable tv cable. Screw a cable into the "out to tv" on the back of your DVD and screw the other end of the cable into the "RF" INPUT (or cable input) connector on the back of your tv. Be sure to look ALL through your TV menu and DVD menu. The DVD sets to "component OUT" and the TV sets to "component IN". Hope this helps.
Mar 04, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Durabrand DWT1304 13" TV Logo
216 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
