Question about Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Minolta 700si rewind Problems
Hi all . desperately looking for solution to my problem. Have a Minolta 700si which will rewind when it comes to end of film . Any help would be appreciated
    Champion:
  • 217 Answers
I dont get it! All I know is that almost all of film cameras rewinds when it reaches the end of film. Find the switch that turns off the autorewind function.
Posted on Sep 01, 2007
Why doesn't my minolta 700si urn on?
Check for battery leakage in the battery compartment. Check the battery contacts. Make sure they are orientated correctly
Jul 10, 2014 | Minolta Maxxum 700si 35mm SLR Camera
Rewind crank is loose on my Minolta XG 1 Film SLR
There is a spring in the bottom of the rewind knob that holds the crank, and it sounds like it has dislodged or the plastic rewind knob is cracked (try small amount of super glue for this). You can rewind the knob off the shaft (open the film door and put something in the rewind fork to keep the shaft from moving) and then turn the rewind knob opposite the direction of the arrow (if the arrow says turn clockwise, then turn counter clockwise). This will allow you to remove the rewind knob assembly and check it for damage, etc. Also, there is a small shaft at the end of the crank. Make sure it is not bent.
May 16, 2014 | Minolta Photography
The battery in my Minolta Maxxum 7000 died while rewinding. I replaced the battery, but nothing happens and the rewind-button/slide is stuck. How do I reset this slide, so I can rewind my film?
Sorry to hear you're having troubles with your Minolta. First thing I would do is make sure that the batteries you put in our good and that you do have power coming out of that battery box. He didn't mention whether the batteries had corroded or if there had been any corrosion previously. The rewind button on this camera will not reset until the camera again advances. In other words it is an automatic release on the camera fires the first time after a rewind. So as an beginning answer to your question I would check the batteries again make sure that all contacts are absolutely clean and as you may have noticed the battery boxes on the Minolta do pivot. The contacts under the pivot points also have to be clean. If you checked all of these issues and you're still having problems please feel free to e-mail me at, Dave@advancedcamera.com.
Thank you good luck
Aug 10, 2011 | Minolta Maxxum 7000 35mm SLR Camera
What sort of a card goes in to the card slot of the minolta dynax 700si and what does it do if not store images
The cards are known as "Creative Expansion Cards" and add features to the camera. You can find much more information here.
Jan 14, 2011 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
What is type of memory does minolta dynax 700si wear ?
Thats a 35mm Film camera - so does not use electronic memory
So you can use any 35mm Film in the camera,
Apr 03, 2010 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
I have a Minolta 700si and want to put a MD Zoom Minolta Celtic 100-200mm lens on it. Is there an adapter that I can get to use this lens and have it fit properly?
There were years ago, but you did not have auto-focus or metering as I remember. Also there adapter had an optic that was not too good so the lens lost a lot of quality when used. Get an SRT-101 for use with the Celtic lens.
Nov 23, 2009 | Minolta Maxxum 700si 35mm SLR Camera
Also have a Minolta 700si flashing HELP
Remove battery. Verify its good. Replace battery in camera. try now.
Jul 24, 2009 | Minolta Maxxum 5000 35mm SLR Camera
Minolta 700si rewinding film before its finished
change the gers ,in minolta rhere will be a bule gare wich wok for forwinding the fillm and rewinding .the gare size will be 32.try this or find the gare that drive the all gares
Mar 20, 2009 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
Rewind runs but film still seems stuck & won't rewind-Max 3xi
It could be that there is a broken or missing gear in the rewind. It will spin but not catch. Sometimes when film is loaded it, is not drawing the film across and missing a gear, so it seems like your taking photos and its not. If you sent it to minolta, good luck, they were bought out by Konica, and probably didnt' do a thorough analysis of it.
I have a friend who fixes cameras. Cleans them, lubricates them, and callibrates them,
http://www.cameradr.com/
Hope this helps you
Nate
Dec 30, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Camra crashed
If the camera is going into rewind mode as soon as it is switched on you should check the manual rewind button and make sure it is not stuck in the on position. It is only a small rubber button that you would use a fine pen tip to push in, sometimes they can get stuck inside the cover and end up being on all the time. This model I think has the button on the bottom of the camera.
Nov 13, 2008 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 7 / Dynax 7 35mm SLR Camera Logo
202 people viewed this question
Top Minolta Photography Experts
TC CAMERA REPAIR.Com...
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
