Question about Toshiba CZ27T31 27" TV
Audio, but No video when connecting DVD player to TV
Hello, I own a Toshiba SD-3750 DVD player and a Toshiba CZ27T31 27" tv. TV is 10 year sold, DVD 5. I have had them connected via a receiver for the past five years with no problems, but my new place does not afford enough space to do this any longer. When I connect them directly, I get audio, but no video. I have tried tv/video button, changing channels, etc with no luck. Any ideas are much appreciated. Thanks!
  • Anonymous Oct 09, 2008
    Same problem but with my xbox
    Novelist:
    Champion:
  • 275 Answers
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Posted on Apr 16, 2007
Tip
Toshiba SD-3750 Manual Download
Download Toshiba SD-3750 DVD Player Manual
Have you misplaced your Toshiba SD-3750 DVD player Users Guide?
Would you like a digital, searchable, pdf version of the Toshiba SD-3750 DVD player Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
on May 02, 2010 | Televison & Video
Tip
I hope that helps.
on May 02, 2010 | Toshiba SD-3750 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Connecting DVD Player
Connect the DVD player using the audio/video cable (yellow,red,white) to the input on the back of your tv. yellow cable to yellow input and so on
Jul 09, 2009 | Toshiba SD-3980 DVD Player
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Aug 30, 2008 | Toshiba 27DF46 27" TV
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Toshiba CZ27T31 27" TV Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
