Vista internet connection through Linksys router only partial
Internet worked til router reset. Then wouldn't work at all. Unplugged all connections, turned router on off, re-reset it, and now get partial connectivity.
During all this time two other computers, both XP, one wired, one wireless, worked fine.
Currently, CNN.com loads, NYTimes.com loads until graphics8.nytimes.com, then hangs, consumerist.com loads until cache.consumerist.com,then hangs, etc.
AVG will not update, filehippo update determines needs, can't download from fpdownload.macromedia.com (hangs.)
email identifies email to be downloaded, but will not retrieve it. I can send e-mail(!)
  • CJNZ Feb 23, 2009
    Wow, I have the same issue - thought I was going nutty since the symptoms are so odd! Just started 2 days ago. Linksys WAG325N and a new Dell Studio laptop running Vista. I've tried a rebuild of the laptop, firmware upgrade to 1.00.12 for the router, factory reset the router, but no luck. Another Vista PC does same thing (can ping sites, even tracert some, but trying to browse them it won't work. An XP laptop from work plugged into the router works fine. Even weirder though is I can take the Vista laptop and router to another site and it works fine - the only difference is the location has changed (and the lead from the router to the telephone wall socket)!
    Problem Solver:
  • 11 Answers
Go to Network and sharing center, then network connections, right click you your network connection and choose properties. Then choose Internet Protocol Version 6 (TCP/IPv6) Does it say "obtain ip address automatically" ? Do the same for Internet Protocol Version 4 (TCP/IPv4).
Posted on Dec 28, 2008
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
Dec 28, 2012 | Computers & Internet
How do i get my linksys router to work
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
May 05, 2012 | Linksys Wireless Broadband Router,...
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Can connect computer to internet through modem but not modem-router-computer. Everything worked fine until I accidently unplugged and reset the router the other day. My computer can connect to my wireless...
Use the reset button on the back panel of the router. You will need a pen or toothpick to press the reset button. Once you reset the router, then configure the router as if new.
Dec 10, 2009 | Linksys Wireless-G WRT54G Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot obtain internet through router
Try resetting the router and modem. Unplug them both from the electrical outlet. Leave them unplugged for at least 1 minute. Then plug the modem in, let it establish a connection, then plug the router in. Do this with your pc turned off. After you reset the router and modem, plug them all back together and into the pc, then turn the pc back on.
Aug 23, 2007 | Linksys A+G WRT55AG Wireless Router
Computers & Internet Logo
505 people viewed this question
Alun Cox
David Payne
David Payne
