Question about Nextar X3 GPS Receiver
Time will not save to GPS
Every time I change the time zone and time, it does not save. When I go into the navigation mode, the time is always an hour behind.
I had the same problem; go into Navigation > hit "I agree" > hit "Menu" > hit "settings" > hit "Localization" > then choose whatever timezone you're in. I'm in the eastern and mine was set to pacific.
Hope this helps.
Posted on Dec 26, 2008
Setting the clock in a 2006 Jeep GC w/ navigation system
Yes this is a little confusing!! It is set from the Nav window. Depress Nav and scroll down to clock.
Depress clock and you can daylight savings option or set clock
Hope this helps?
Other Jeep Radios
1. Press the MENU hard-key on the right side of the
radio.
2. Then press the System Setup soft-key to get to the
System Setup menu.
Set the Time
1. Press the time soft-key in the lower left corner of the
screen.
The minutes are set by the GPS system.
2. Press the Set Time Zone soft-key to change to the
desired time zone.
3. Press the Daylight Savings soft-key to switch Daylight
Savings on or off.
It is possible to set up your own time (ahead or behind
actual GPS time), by pressing the USER CLOCK soft-key.
NAVIGATION 15
Nov 08, 2016 | Jeep Cars & Trucks
How do i change the time on my Tom-Tom
To select the time format and to set the time, follow these steps:
  1. From the main menu, tap Change preferences.
  2. Tap Set clock.
  3. Select how the time should be displayed and then tap Next.
  4. The easiest way to set the time is by tapping the Sync button. Your navigation device will then take the time from GPS information.
    Note: You can only use Sync if your device can receive a satellite signal, so you cannot set the clock in this way when you are indoors.
  5. After using Sync to set the time, you may have to adjust the hours depending on your time zone and the daylight-saving time.
May 23, 2011 | Tomtom ONE GPS Receiver
I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
1. press "MODE" (it will show the alarm time)
2. press "ADJUST" (this will switch the time zones)
3. when it is on the desired time zone, press "MODE" to return to the clock.
Mar 15, 2011 | Audio Players & Recorders
The safety lock is enabled and I am unable to turn this off. I am also unable to navigate to an address or favorites. It is also on the wrong time zone.
The safety lock is active only while the device is moving. When you stop, you can access all buttons again. To switch off the feature,
  • Tap the map display to go to the device main menu
  • Tap "Change Preferences"
  • The TomTom XL device hides many menu options by default. If you can see an icon "Show ALL menu options", tap this one next. It should show as "Show fewer menu options" now.
  • Locate the icon "Safety Preferences" (a red heart on blue background) and tap it. This will allow you to deactivate the safety lock feature.
  • You may want to hide the lesser used menu options again.
In order to set the time properly:
  • Tap the clock button to set the time and to change the way the time is displayed.
  • The easiest way to set the time is by tapping the Sync button. Your ONE XL will then take the time from the GPS information it receives.
  • After using Sync to set the time, you may have to adjust the hours depending on your time zone. Your ONE XL works out your time zone and always keeps the time correct using the GPS information.
  • You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
Dec 28, 2010 | Tomtom One XL GPS Receiver
The time on my gps 1440 is 1 hour fast?
To switch between Daylight Saving Time - on or off:
1) Turn on unit - Press the picture of the wrench and screwdriver at the bottom.
2) At the next page, select "System"
3) At the next page, select "Time Zone"
4) Select "Daylight Savings Time" at the bottom to toggle it on or off
Jan 08, 2010 | Magellan RoadMate 1440 Car GPS Receiver
My magellan maestro 4040 is an hour ahead on the time. I have tried changing the time zone and region but no luck. Any ideas?
did you check off for daylight saving time?
its in the time zone settings..make sure the magellan is acquiring the satellites (it it displaying your location...if it is, its probably because the daylight savings time isnt checked
if thats not the problem, let me know and ill help you further.
bill
Dec 29, 2009 | Magellan Maestro 4040 GPS Receiver
Change time
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> --> Question Setting the clock Answer To select the type of clock that is shown and set the time, tap Change preferences > Set clock.
This feature is only available on your navigation device. You cannot use this feature in TomTom HOME.
  1. The easiest way to set the time is by tapping the Sync button. Your navigation device will then take the UTC time and date from GPS information.
    Note: You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
  2. Adjust the hours depending on your time zone. Your navigation device works out your time zone and always keeps the time correct using GPS information. You only need to adjust the daylight-saving time.
Nov 10, 2009 | Tomtom ONE XL GB Car GPS Receiver
How to set the current time.time did not change when we turn the clock back one hour.
either your 1440 was never set to include daylight saving time or the unit was reset at some point.
the time is automatically set once you choose your time zone and if you observe daylight saving time, you must check that box..
go to the main menu, then system option and click on the time zone tab, then select your time zone and check off the little box for daylight saving time.
bill
Nov 06, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Nextar X3 GPS Receiver Logo
112 people viewed this question
Top Nextar GPS Experts
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
