Question about Samsung RS2630SH Side by Side Refrigerator
Ref has no power
We had power outage problem for more than 1.5 hours in the local residential area last night (12/24). We found out the ref. does not response to the control pad on the door - no temp. on either ref or freezer.
  • alicefang01 Dec 25, 2008
    Thanks for the reply promptly, we'd reset gfi but it's not a plug-in problem. In fact we found a solution submitted by user rwparker1. (listed below) After we followed the instruction, our ref is up running! :-)
    Ok, what I found out is that there are codes built into the front
    panel. If you hold the top left and right buttons for 5 seconds, the
    fridge will reset. If there are no issues, the panel goes blank. If
    there is a dash in the right side of the panel, there is an issue with
    the fridge side. In the left, freezer side. The dash indicates a
    defrost problem. Only a couple of things can cause this. 1. Sensor 2.
    Heater 3. Fan, 4. control board.
  • 700 Answers
First thing to do is to make sure that the plug is hot that your refrigerator is plugged into. Most of the time it's a gfi and it may need to be reset. if youi don't see it there sometimes the electricians will pu it in the garage and or the bathroom but it is still on the same circuit. Hope that htis helps you out.
Posted on Dec 25, 2008
  • Todd Born
    Todd Born Dec 25, 2008
    that great have a wonderfull day
Why did Kenmore series 110.60202990 dryer stopped working after power outage?
check electric box, termo fuse on air duck (white 2 wires normally blue)
Jan 05, 2015 | Kenmore Dryers
Internet went out on the wireless router and it will only stay in local only
Hello
First check with your internet provider if any outages are reported in your area.
Next try a reboot of the router.
1 Pull all cables ot of router,including power.
2 Find reset button,usually in the back use a pen tip or paper clip to hol it in for 1 min.
3 Reconnect cables,power last. Then power up router.
4 Turn on pc.
May take a minute or two to find the internet again.
Jan 08, 2011 | Computers & Internet
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
After power outage I Can't connect without bypassing router
If you can connect directly then, the problem is the wrt54g router. Possible problems:
1) Power Outage damaged the router
2) Power Outage reseted the router
For the second scenario, you should got to the browser and type: http://192.168.1.1/ and check whether you can enter or not. If not, you need to configure the gateway IP on your PC to 192.168.1.1
May 25, 2009 | Linksys Wireless-G WRT54G Router
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
Loud fan and wont turn on
power supply is probably shot and you are feeding a voltage way over what is needed. I have a dell that refused to operate one day. I went to www dot affordablesurplus dot com and found a 350 watt power supply with all the RIGHT plugs. Never had a problem since.
Dec 04, 2007 | Dell Dimension 8400 power supply ** FREE...
Power outage last night. Deleted all saved voicemail messages. when turned on - machine says "no massages" How do I retrieve lost messages?
I'm sorry there isn't. Answering machines like this have very little ROM memory. After a powersurge and outage like last night, it wiped the whole memory chip. You can try there support page. It's actually pretty good. http://telephones.att.com/telephones_ui/support/index.cfm
Jun 28, 2007 | Lucent 1872 Corded Phone
Samsung RS2630SH Side by Side Refrigerator Logo
111 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
