Question about Canon PowerShot A520 Digital Camera
My camera just shows no image.
I turn on my camera and a message say the camera has no image. how do i getit to work again.
This could be a silly question, but do you have the litte thing switched to show pictures instead of taking pictures?
Posted on May 02, 2007
SOURCE:
Error message-no images
Try taking any image, save then, see if the if you still get error message
Nov 05, 2017 | Polaroid i737 Digital Camera
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
HOW DO I CORRECT MY CAMERA WHEN IT SAYS LENS ERROR21
HI there try to reset the camera from menu & then setting option. After that turnoff & again turn on . Now try for click an image. If you face the same problem then the error message show is the right cause. Its mena the lens guide pin is damaged or dislocate. Replace or repair that . Thanks & waiting for your feedback,
Mar 24, 2010 | Sanyo VPC-E760 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Showing turn the power off and on again.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu under Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Oct 19, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Will not record nor replay.
I Had The Same Problem I Just Turned The Screen A Different Way And It Worked Again
Jan 07, 2009 | Video Cameras
When I turn my Sony Cybershot 7.2 mega pixel camera on, the lens keeps going in and out and the message "Turn the Power on and off again" shows up on the LCD screen. When I turn the power off and on again,...
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Dec 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Please turn camera off and then on again after a couple of seconds
Hello friends,
My Panasonic Lumix dig. camera Screen is showing the message that pl. switch off the cametra and on again. when i did the same again I face the same problem. Pl. help me to solve the problem
Apr 24, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Memory "locked up"?
My camera does that too. If you mean that your camera says that there are no images, then all you have to do is start taking pictures all over again. these will show up in the memory. if the computer says that, im not sure what to do. hope this helps
Oct 11, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A520 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
