Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25PGMCC refrigerator freezing food
This side by side refrigerator we keep in the garage. Lately, it freezes food on the refrig side. Does it sound like a thermostat problem or what should I check first? I've turned the thermostat down to "1" and it still freezes.
  • 7 more comments
  • tact317 Dec 25, 2008
    We have the manual and I didn't see in there where my problem is addressed. Food in the refrigerator side is freezing.
    About 47 degrees.
    My temp controls looks like what's on page five but I checked in inside of my refrig and I don't see a rating plate, but I just now read in the manual to not install it where the temps will go below 60 degrees F. Could I have damaged my refrig? I've had it in the garage for three years now and never had a problem. Could this be what's causing my foods to freeze?
    Where do I go to get on live chat with you?
    I've turned my controls to "1" but I haven't heard it cycle yet.
  • Anonymous Feb 26, 2009
    My older Magic Chef is leaking water that freezes on the bottom of the freezer side and the food in the refrigerator side is now freezing. HELP
    I have an older side by side Magic Chef. It is leaking water out of a vent on the freezer side which pools and freezes on the bottom of the freezer THEN the food on the refrigerator freezes though the settings are not changed. I lost my manual. Help!
  • keithupsman Feb 26, 2009
    food in frig side is frreezing.. i replace the main board of the electrical and its still freezing ..though not as fast..i turned the temp down to 1 in the frig and its still tooo cold .the food frrezes..
  • Anonymous Mar 21, 2014
    coils clean , refrig running great just freezing everything in refrig side.
    refrig side freezing every thing, coils clean
  • 700 Answers
Hello I think that this is what you are looking for . Hope it helps you out with your problem.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60218.pdf
Thank You for using FixYa
Posted on Dec 25, 2008
  • 3 more comments
  • Todd Born
    Todd Born Dec 25, 2008
    what is the temperature inside of the garage right now?
  • Todd Born
    ok then ccould you please read pages 6-7 regarding the ambient temperature limits for the unit please.
  • Todd Born
    ok now lets figure this out you have the temperature controls that are inside of the refrigerator turned all the way up right?
  • Todd Born
    go ahead and turn it to 2 and then turn the outside controls should start working again they do that for enrgy saving purposes.
  • Todd Born
    this would be faster if you would go live chat with me
MY GE MONO SIDE BY SIDE REFRIG,MDL ZISS480DRSS IS FREEZING THE REFRIG SECTION.THE TEMP READ SAYS IT IS NEARLY 80!I THINK IT MAY BE REACTING TO THE TEMPERATURE DISPLAY AND TRYS TO COOL IT DOWN.HELP!
Here are possible parts that could cause the problem
GE Refrigerator Freezing Food but the most common is the diffuser/damper that got stuck open and cold air from freezer continously coming in to the fresh food side.
Nov 22, 2017 | GE Refrigerators
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
My GE Profile Artica PSI23SCN refrig. temp on the refrig side stays at 27 degrees. I turned up the freezer temp to 6 and the refrig went up to 31. I called arepair guy and he said he had a client with the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 02, 2011 | GE PSI23SCN Side by Side Refrigerator
Ge electra series side by side refrigerator keeps freezing food in my refrigator
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
403 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
