Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Compressor is not working.
I have a kenmore refrigerator. The compressor does not work at all. The light comes on when you open the fridge door. The model# is 253.64834400,
  • Anonymous Mar 25, 2014
    single door Kenmore. Light comes on but not the compressor
  • 306 Answers
Do you still have the problem? And if you do there is a relay on the compressor called a PTC relay that is more then likely bad. Needs to be replaced. Need any further help get with me and will assist. ken
Posted on Dec 27, 2008
Where is damper door in a kenmore refrigerator model #9510681 side by side
If you can't see the damper door, it is most probably shut, possibly frozen or not working. Top of middle section, allows airflow from freezer to fridge part. Switch thermostat off, wait 20 mins, switch back on. If damper doesn't open, check stat and damper motor.
May 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
We have a Kenmore Elite 79577554600 Refrigerator. The temperature display is freaking out. The numbers keep changing, lights flashing on and off, temperature counting down from 44.
It is running in "store-demo" mode. Fancy light-show, and the compressor turns off (bad!)
Hold down the right-most two buttons (Ice and refrigerator temp) for about 5 seconds. I think the right-door needs to be open for this to work, but not sure.
This will activate the fridge once again.
Dec 24, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Hi, I have a whirlpool gold side by side fridge/freezer. I came home the other day and water all over the floor. I opened the freezer and it wasd hot. Opened the fridge, same thing. Light and fan work and...
Quick reference to your compressor says that it is a 120 V powered regular compressor.
It might be simple as starting device failure on compressor. Either capacitor or relay. Worst case compressor gone. Still not crazy expensive compared to a DC powered compressor.
Shut off the fridge (pull the plug) to prevent further damage to compressor and call a local service guy if you want to save the fridge.
Oct 25, 2017 | Kenmore 55603 Side by Side Refrigerator
The fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
the fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
Mar 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Won't cool any more
What do you mean turns on. The light inside is on. Do you hear the compressor coming on. If you hear the compressor turning on and the fridge doesn't get cold, compressor might need freon. If compressor doesn't turn on, your timer is not working
Jul 23, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Kenmore fridge won't run after cleaning fan motor
Check the thermostat and make sure it is sending power to the compressor and fan. If the light comes on when you open the door then you have power to the unit. Make sure you hooked all the wires back up and in the right location
Jan 26, 2008 | Refrigerators
Not cooling
- Check if there power is a supply by opening the door of fridge, if there is a light then there is a supply. But no light check the circuit breaker. Or try another outlet for testing. If your fridge is digital control and there is some error display, then reset the error.
- Check the thermostat setting if set to high cool, and check the compressor at the back of the unit if running, if not there is something wrong to your control or compressor itself, if the compressor is operating and no cool at all maybe your unit is out of refrigerant, please call a qualified technician.
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
