Question about Combi Centre DX - Mango
Need to repressurise my worcester 28si combi boiler
Dont know what to do with the key
  • 13 Answers
Most worcesters have n internal filling loop, depending on which one you have i.e CDi (left hand side, or Greenstar/ junior (high efficiency) right hand side, there ill be a void, the filling loops are black plastic with either a small grey or white knob, position your filling key pointing up, with the little noggins poiting at 3 and 9 o'clock, so it looks like your putting the key in on the wont almost. Push it up, and twist. (older worcester turn it 45 degress), newer worcester turn to the right slightly, you'll know if its in right because you cant turn it any further on the newer ones. turn the small knob anti-clockwise to let water in, unitl the reuired pressure is reached. Normally 1- 1.5bar is adequate. If you key isnt in right water will come out where the key is. So if it does it means the key isnt in right, dont panic, turn the knob off and try again. Once done, twist key back to its original position and pull out, youll probably gets a few drip out, this is normal.
Unforuntely not the most user friendly of devices if you dont know what your doing.
Good luck
Posted on Jul 10, 2009
Need to know how to switch off hot water by combi boiler worcester bosch 240 to be able to fix leak on pipe downstairs
its the vavle 3 one in from the left its a 15mm pipe and there will be a iso vavle what you can turn with a flat point screwdriver and that will turn off the main water to the boiler these are the manual
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/240-bf-discontinued-december-1997-literature
Jan 23, 2011 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
Oct 14, 2009 | Water Heaters
Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Jan 07, 2009 | Heating & Cooling
Faulty Worcester boiler
we have a worcester24i rsf boiler installed in our mobile home buy the the water temperature seems locked in at a certain temperatutr any idea how we can change this
Oct 19, 2008 | Combi Centre DX - Mango
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Combi Centre DX - Mango Logo
953 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
