Question about Wolverine FlashPac 7000 120 GB USB 2.0 Hard Drive
When I insert my card and push copy I get SD lait
What does SD lait mean with a blinking light. I have a 7080.
  • barbarahedri Dec 25, 2008
    Are you serious?
  • 126 Answers
It means it is broken. buy a new one, honeslty is not worth playing around with for the price of it.
Posted on Dec 25, 2008
How can I add more memory to the Hero 200 phone
you need to purchase a micro-sd card to expand the memory.
May 03, 2011 | HTC Hero Smartphone
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
Dec 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
42hl67 has a continuous blinking yellow light in 3 blink intervals, how do I fix this?
May 09, 2010 | Toshiba 42HL67 42 in. LCD Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Feb 24, 2010 | Toshiba 65HM167 65" Projection Television
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
Toshiba Regza 37in - 37HL17
TV will not turn on Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Sd driver not working
try to insert the sd card slowly and watch the blue light if starts to blink that means it is reading your memory card then that must be the depth u can insert your memory card for the reader to work. hope this is helpful
May 12, 2009 | HP Pavilion dv1000 Notebook
Cannot copy photos from my SD card
If the printer is connected to your PC with the USB cable then as soon as you insert the SD card in the slot it acts as a drive. Open up "My Computer" and search for the new drive (e.g. E: or I:). You can explore the SD card as you would with your hard drive and you can copy the photos on the SD card to your computer as you would normally copy files.
Apr 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
My New Micro SD Memory Chip
i need help. i insert my lexar 1gb micro sd memory card into my phone and my phone doesnt show that there is a memory card inserted and i have no idea how to work it on my phone. my phone is a samsung blast.
Jul 31, 2007 | Samsung SGH-D900 Cellular Phone
Wolverine FlashPac 7000 120 GB USB 2.0 Hard Drive Logo
147 people viewed this question
Top Wolverine Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
