Question about Cuisinart DCG-12BC Electric Blades Grinder
Need help using my coffee maker
I just bought a Cuisinart Grind and Brew  coffee maker at Linen and things at closing of store. Didi not come with Manual. I cannot figure out how to use it. Cannot get it to brew. Can I get manual from Cuisinart. Or can I get help on using it. Am dying to try a cu of cofee with it.
Thank you for note I went on Cusinart site and found a copy of the manual and got my coffeemaker to work.
Posted on Dec 26, 2008
  • Esther Vega Oct 23, 2013
    My coffee maker did not come with a manual, kitchen-aid (KCM1110B) :((
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker's on/off light is blinking and cant get it to start
Hello. Please check to make sure the grinder is assembled properly and the lid is completely closed and snaps shut.If all this isn't right it will make a beeping sound.If that doesn't help unplug it for a few minutes and start over with the time setting etc. If you dont have a manual you can download one at www.cuisinart.com.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I need an instruction manual for the cuisinart coffee maker DGB550BCU can any one help or tell me where to get one. Thanks
There is a free downloadable manual for the DGB550xxx series of Grind and Brew coffee makers.
Here's the link with the free downloadable manual
http://www.cuisinart.com/manuals/coffee_bar.html
Hppe you find this info helpful.Best regards!
Jul 02, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Automotic Grind & Brew Coffee Maker
http://www.cuisinart.com/manuals/index.php?item_id=34
Jun 02, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart DCG-12BC Electric Blades Grinder Logo
272 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
