Question about Macromedia Dreamweaver MX 2004
Loading img throught xml
I want to load images through xml in flash with some intraction
    Problem Solver:
  • 16 Answers
Gotoandlearn.com , http://www.kirupa.com/developer/mx2004/xml_flash_photogallery.htm
Posted on Apr 23, 2009
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
Bootable dvd
Make an ISO image and burn it on a different DVD and you will be able to boot it. make sure the source is bootable.
Jan 04, 2010 | Microsoft Windows Vista Home Premium with...
How do I load several swf files and use 1 xml?
The easiest solution is to put all flash files in sub-folders, and link them in Dreamweaver from the files in the root folder --- but the key, AFTER uploading to your server, is to change your MANAGE SITE CONTENT information with your host server. Specifically, change (advanced) PERMISSIONS to READ and EXECUTE (DIRECTORY). It's important that both are checked… If you don't do this you'll see that it works fine on your local machine, but not after uploading to your server.
May 12, 2009 | Macromedia Flash MX
Javascript code equivalent to PHP given below.
You can load a XML fie from JavaScript like this:
var xmlDoc = new ActiveXObject("Microsoft.XMLDOM");
function loadXML(xmlFile)
xmlDoc.async="false";
xmlDoc.onreadystatechange=verify;
xmlDoc.load(xmlFile);
xmlObj=xmlDoc.documentElement;
http://www.sitepoint.com/article/server-side-xml-javascript/
Apr 30, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Cannot download cd
I don't understand the question? is it suppose to fit throught he screen. haha.
1)is the problem with the link?
2) is the problem with the hard disk space?
3) maybe you are down loading it but don't know/remember where it went/is. you could do a recsent search - try to remember the name of the file
4) is the popup blocker on. top of the screen. click on yellow bar. yes to download file. I think the short cut key is <shift-enter>
5) cdrom is an IMAGE file iso img ect. you need a burnning toollike nero to reburn it to a real cd
6) you have the cd , faulty cd it happens.
let me know if any of this helps :)
Jan 17, 2008 | Palm Z22 Handheld
Plat swf files sequentionally from xml
I've finished your requirement almost but how do you read the swf files from the xml one by one? My code will parse the xml and open the swf files one by one and so you can only view the last swf file.
var myXML:XML=new XML();
myXML.ignoreWhite=true;
myXML.onLoad=function(success){
    if(success){
        for(var aNode:XMLNode = this.firstChild.firstChild;aNode!=null;aNode=aNode.nextSibling){
            loadMovie(aNode.firstChild.toString(),_root);
myXML.load("sampleFiles.xml");
And your sampleFiles.xml should look like this:
<swf>
  <swf1>sample1.swf</swf1>
  <swf2>sample2.swf</swf2>
  <swf3>sample3.swf</swf3>
</swf>
Oct 08, 2007 | Macromedia Flash MX
Macromedia Dreamweaver MX 2004 Logo
78 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
