Question about Kitchen Ranges
The word ''door'' displays on the oven clock
I have a Magic Chef slide in range/oven model 6892xrs. The range had been throwing F1 error codes when power when the stove had power but nothing was turned on. The membrane switch stopped working altogether. This week I replaced the membrane switch, and everything seemed to be OK. No more error codes, and each of the membrane switch keys worked properly.
This morning we turned on the oven to make breakfast. The oven started to heat up, but then shut off. There was no error code in display, and we were able to turn it on again. Once again, it heated up, but then shut off. This time, when we went to turn it back on, it displayed ''door'' in the clock display (no beep). If I press Stop/Clear and hit either broil or bake, it again shows ''door.'' The door latch for self cleaning is all the way to the left (i.e. not engaged). It's almost as if the logic in the stove is telling it that the oven is in self clean, and once it gets to a certain temperature, it checks to assure that the door is latched, finds that it isn't and shuts cuts the power to the oven.
I am able to close the self clean latch and initiate self clean. I have that going now and have about 2 hours to go. Don't know whether that will clear this problem, but I didn't see any harm in trying.
Do you have any idea what might be causing this behavior? Is it the clock module? Is it a faulty relay board? Is there any way for me to determine the cause using a multimeter?
John Freedman
  • John Freedman Dec 25, 2008
    jithin4043 responded to my problem with:
    i think it is due to the problem to the washers which preserves the heat inside the instrument and the sensor may have detected some kind of leakage.try to check it out and provide the necessary.thank you "
    I am not familiar with washers in the context of the range. Does jithin4043 mean the gasket between the oven door and the oven? jithin4043 could you or somebody please provide some clarification?
    John Freedman
    President:
  • 2,110 Answers
Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control panel (without the electronic control) but on some models the keypad linked below can be used to repair the one on the original control panel.
Posted on Dec 25, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, as the error code name implies, fault is with the door. To my knowledge, common electrical arrangement would have two (2) types of door switch; door is closed and door is locked. The error code could be referring to either. Both switches are also sensors and indicates a simple on/off condition and therefore could be tested for continuity. Both could also possibly be wired to the logic controller to tell the controller of its state and for the controller to take action (as in your case auto shutdown). Since the door would be often used (abused), I am inclined to think that the door/door switch could be the most likely suspect or at least parts related/affecting it.
In most units, there would be a tech sheet at any of the panels perhaps at the bottom/kick panel (if one is present). Said tech sheet would contain error codes and user action possible to address said errors.In most cases, there is also a wiring diagram which could assist you in further diagnosis.
Should you be interested, there is an exploded parts diagram which may help you locate the different parts here.
Would appreciate an update on any developments. I have a funny feeling on the "self-clean". It either corrects your fault or cause the door to be stuck at lock condition.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 365 Answers
I think it is due to the problem to the washers which preserves the heat inside the instrument and the sensor may have detected some kind of leakage.try to check it out and provide the necessary.thank you
  • JITHIN ANTONY Dec 26, 2008
    does the problem solved
    yes i mean the gaskets and you have exactly said it .is there any problem with that.have you checked it
My magic chef gas oven showed the F1 code. I tried to self clean the oven and some wires under the cooktop started to melt and smoke.
Hi nelson1999,
F1 error description is a defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Jan 27, 2011 | Magic Chef 31000 Gas Kitchen Range
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
Magic Chef gas stove periodically starts beeping and "F-1" appears in the display
Hi alflaw,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Feb 05, 2010 | Magic Chef 31000 Gas Kitchen Range
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
Hope it helps.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
181 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
