Question about Nikon Coolpix 5900 Digital Camera
Display is rotate?
My display it's rotate in left side 4-5°, and in option & set up I don't detect solution this problem?Display is
0 characters
1 Points
My LED display is not working.
Check the menu settings for your display. On page 50 you can see you can set the Image review Time to 2, 4 and 8 seconds as to Hold and Off.
Just using the manual, can help to understand your camera and its functions. e5f7c9a3-abdd-45cd-9f51-e6581641176b.png
Jul 06, 2014 | Canon EOS 60D Digital Camera
WHEN i TAKE LANDSCAPE REPLY SHOWS PORTRET AND WHEN PORTRET TAKEN REPLY IS ALSO TURNED 90 DEGREES PLEASE ADVISE that Further to crhendo1's Findind's - i have found that if Picture with the EXIF Orientation set to "lower left" (ie one that needs Rotating) is first imported into iPhoto or Aperture and then displayed on the ATV (ie iTunes is set up to share/stream from iPhoto or Apeture)- all is fine - ie picture is displayed correctly rotated.
However, if the pic - left as a Jpeg - is place in a folder - on a Macbook Pro, or a Windows PC - and iTunes is set up to share/stream from that folder - then the picture will be displayed on its side
Futher more - if you then export the Picture from the iPhoto/Apeture Library - and put it in a the folder it is also displayed correctly rotated
for further information visite this website
Jul 11, 2011 | Digital Cameras
Display mode will not go off
Does your camera have a viewfinder? If it does press the display button or change the display settings in your camera's menu. Also, many of the recent camera's that don;t have an optical viewfinder don't give you the option to turn off the display.
Photo Tech Repair Service
110 East 13th Street
New York, NY 10001
Jul 01, 2011 | Samsung Digital Cameras
At night cannot see screen and therefore cannot see what I am trying to tak a picture of and dont know how to make screen brighter
On Auto Setting, hit menu, then scroll down until you get to the display set option. It will have small graduated lines on the left side, and say "bright" on the other. That's your lcd display brightness setting. Good luck!
Mar 28, 2010 | Olympus Stylus 400 Digital Camera
Camera Turns off when Display is rotated then closed
ur strip line is broken dont use ur screen with more rotation
Jun 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Date and time not showing on the viewer or pictures
You can choose to have date and time show or not. If you can do this it will be in your menu settings, either under the date and time set up where you will find a menu choice for this or you will find a choice on the menu scroll down that says display date and time. Your manual should give you the instructions.
May 04, 2009 | Sony Alpha DSLR-A350K Digital Camera
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Canon g5 lcd display problem
I had the same problem but did not have a soldering iron small enough and did feel adept at soldering microcircuitry in any case.
I unscrewed the four side screws, rotating the screen slightly to get at the ones closest to the body of the camera. Carefully removing the back I turned the camera on and noticed that by pressing on the two contacts located at the bottom left where all the circuitry is, the screen came back on full brilliance. I cut a small piece of plastic off of an old credit card approximately 1/2" X 3/4" of an inch. I then folded it in half (biting it tight and then opening it to create a bit of spring). I then carefully placed this double thick plastic over the contacts in the lower left and sandwiched the cover back on. Pressing it tight and put the screws back and voila!... works like a charm. The double thickness of the plastic and little extra pressure from folding the plastic over and opening it a bit was just enough pressure to solve the contact problem.
I expect some technicians will think this is kind of a *cheat* but from my experience with soldering - especially tiny stuff, I just did not feel comfortable with that option. Anyway hope it helps some other novices, it is a quick fix.
Artist3d, Still lovin my Canon G5
Sep 02, 2008 | Canon PowerShot G5 Digital Camera
Date and Time
Do you have the Camera User Guide~~~It tells you how to set it on p37
I found this on the Camera User Guide
steps the function/setting button
2.on the left side,there's a column displaying various features, and then you go to select the very last one, and then it will displays more options for you to choose(L,M1,M2,M3,S, postcard,etc), and then "postcard" is the one you should choose.
3.After that, go to "menu", go down to the very bottom on the option list, you will see that the "Date Stamp" is being set "off", go there and choose other options (date/date and time). This is how you can display time on the pictures.
Jul 09, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Taking a smaller image from S80
In picture-taking mode, hit the Func Set button. You will see menus of options along the left side and bottom of the display. Tap the bottom of the scroll ring (the ring around the Func Set button) until the bottom option of the left menu is highlighted in red. This option sets the image size of the pictures you are taking. Change this size by rotating the scroll wheel. The 5 options are Large, Medium1, Medium2, Medium3, and Small. The image size in pixels is displayed above the bottom menu as you switch between sizes. When finished, hit Func Set again.
Jun 25, 2007 | Canon PowerShot S80 Digital Camera
Nikon Coolpix 5900 Digital Camera Logo
29 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
