Question about Haier BC112G Wine Cooler
Ice is forming on the rear of the Haier wine chiller
Wine is chilling but ice is forming on the rear of the chiller...should we first defrost and possibly blow the drain?
  • controlpav Feb 17, 2009
    I have a Haier HVW18ABB 18 bottle thermoelectric wine cooler and ice is forming on the inside of the lower thermoelectric heat exchanger causing the fan to scrape on the ice.
    Does this type of circuit require a defrost cycle? Or is the unit just running too cold?
    Thanks
SOURCE: haier wine cooler
Hold + and - keys down together until LED blinds (about 4 or 5 seconds), Then press + or - key to lower or raise temp. Once you've reached the desired temp press the set key.
Posted on Mar 18, 2008
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
ramon49
  • 111 Answers
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Posted on Mar 09, 2009
  • 4793 Answers
SOURCE: My Haier wine cooler (Model BC112G) has stopped
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Posted on Jun 03, 2010
woodchuck789
  • 4070 Answers
SOURCE: Ice is forming on the back wall of my freezer
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jul 06, 2010
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
We have a Nscessity wine chiller model number NSWC-06SE and it no longer chills the wine it looks like the thermostat has gone who do i go to for repair it is 3 years old
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Is there such thing as a single bottle wine cooler?
Of course! There is a wide variety of single cooling systems for wine bottles. We don't drink a lot of wine, but when we have guests over I like to have the wine chilled properly. I prefer the stainless steel coolers, since the look more sleek and stylish.
http://www.amazon.com/Vinotemp-VT-CHILLER-SLVR-Bottle-Chiller/dp/B001NFX2QU
http://www.polyvore.com/danby_maitre_single-bottle_wine_chiller/thing?id=541026
Jul 31, 2012 | Furniture
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
My Transtherm Castle wine cabinet has accumulated ice in the lower chilling compartment, I need to know what is involved in thawing/defrosting the cabinet.
Check the thermostat setting; it may be set too high. If lowering the setting does not solve the problem, replace the thermostat.
P.S. The thermostat is what controls the temperature.
Dec 23, 2010 | Transtherm Castel Wine Cooler
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
Jun 03, 2010 | Haier BC112G Wine Cooler
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
Haier BC112G Wine Cooler Logo
71 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
