Question about Westwind Traditional Designers Choice Sandstone Ceiling Fan
Need instructions for Ceiling Fan Remote Control
Hi, I need help in understanding my ceiling fan's remote control. It's a Designer's Choice with Auto, Random, and Delay Off settings. It also has an LED screen. I think I understand how the fan monitors the temp and turns on and off accordingly but I don't understand how the auto and random features of the light work. What I'm hoping to accomplish is somehow avoid having to push the little remote button whenever I enter our bedroom to turn on the light. It's a bit of a pain. Thanks for any help you can offer.
  • Arnold Swan May 11, 2010
    I was wondering if you can assist me in re-programming my remote. I have the same remote as you are describing. I took it out of my mothers house and installed it in mine. However, the remote doesn't work the lights or fan any more. It need to be resynchronized.
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
  • 859 Answers
SOURCE: replacing fan switch
Do you have a meter?
Posted on Jun 03, 2008
  • 10 Answers
SOURCE: how to convert ceiling fan into wireless ceiling fan
Suggest going to Lowe's (or other appliance dealers who sell ceiling fans) and get one of their wireless interfaces -- I have two in my house...  These can be found in the ceiling fan area, probably need to talk to someone as they have several different models...
You will need to rewire the fan slightly, but the diagram for the wireless interface is pretty straight forward if you know anything about wiring...
The interface has two parts -- the receiver which slips into the yoke holding up the ceiling fan, and the handheld controller (there are other units, but I am assuming this is what you wanted...)
hope this helps...  Pablo, Kansas City
Posted on Jul 27, 2008
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
Designers Choice Ceiling Fan Manual
All Hunter fan model numbers are 5 digit and start with a 2. Are you having a problem with the fan?
May 16, 2013 | Hunter Designer's Choice 5-Switchblades Lg...
Remote control B-542
Peter, Home Depot carries replacement ceiling fan remotes.
Check the attached links,remote and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Hunter Ceiling Fan Remote Control Replacement Light Fan Speed...
Hampton Bay Ceiling Fan Remote Control 70830 The Home Depot
Jan 28, 2013 | Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
I have a Hampton Bay Remote Ceiling Fan but Remote is missing. Where can I get one.
1. try ebay
2. stores sell universal remotes that can work most ceiling fans.
Apr 13, 2011 | Universal Remote Control Hampton Bay...
Fan with remote control speeds up on its own
bring the remote control to the store and have its function tested with similar unit. if the control works fine then you have no choice but to take down the fan and have it repaired
Oct 18, 2009 | Hunter 52" Ceiling Fan With Light And...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Nov 24, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
451 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
