I have the same problem. I tried the reset option, and it goes back to time. However, when I push power on button, it locks up again.I have the same problem. I tried the reset option, and it goes back to time. However, when I push power on button, it locks up again.
You can't post conmments that contain an email address.
Not sure what a MOS error is or what its related to
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem Hope it helps.
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Hello, LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit. 1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire. 2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly. Thanks
Possible causes: (power off the mains first before checking) Door
lock mechanism is broken or removed from door. Door switch/lock unit
failure. 1. Check door switch/lock unit. 2. Check the wire harness
connections of the door switch/lock unit to the Central Control
Unit (CCU). The wires shd be secured well.
Try these sites for
spares: RepairClinic.com espares.co.uk AppliancePartsPros.com mcminone.com
hello
Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Try this and see if it fixes your problem...follow these steps. 1. Power off the unit. 2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least). 3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
locked up with hello msg scrolling across display
