Question about Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer
HP OJ 6480 PROBLEM WITH WIRELESS INSTALLATION
When I do the installation I get to the part where it asks about WEP, WPA or NONE for security. I have none, therefore I select NONE. It comes back with an error msg saying Error saving information. I even tried to set a WPA password and it didn't like that either. The biggest value for is the the wireless feature and I can't get past this stage.
Pls help!
Joe Dougherty
  • jolie_ent Jan 09, 2009
    I have solved this problem. Thanks to anyone who tried to help. The solution was to do the set commands on the printer itself, for Wireless hookup. Once done, everything else worked. My disappointment is that HP didn't make this very clear in the beginning of the installation procedure.
  • bandys Feb 15, 2009
    Can't hook up wirelless printer
Printer saying error and I can't get it to print
Posted on Jan 09, 2009
What's the difference between WEP and WPA? What should I pick?
WEP is a weak securtiy protocol that is outdated and can be easily broken
WPA is a newer security protocol that is much harder to break with AES encryption
WPA is always recommended mode for operation over WEP.
Use WPA2 which is latest version if it is supported by device.
Mar 12, 2011 | Belkin N1 Wireless-N Wireless Router
Asking 8digit network key
Sounds like your wireless network is setup to require a password (it has encryption) most commenly used is WPA, WEP and WPA2, you will have to ask the person who setup the network for the password.
Here is some more information from the NETGEAR site on WEP encryption for a wireless network:
What is WEP Encryption for Wireless Networks? Wired Equivalent Privacy (WEP) is a security protocol for wireless networks that encrypts transmitted data . It's easy to configure. Without any security your data can be intercepted without difficulty.
However, WEP was an early attempt to secure wireless networks, and better security is now available such as DES, VPN, and WPA. See the Guide to Internet Security to learn about network security.
WEP has three settings: Off (no security), 64-bit (weak security), 128-bit (a bit better security). WEP is not difficult to crack, and using it reduces performance slightly.
If you run a network with only the default security, where WEP is turned off, any of your neighbors can immediately log on to your network and use your Internet connection.
  • For wireless devices to communicate, all of them must use the same WEP setting. (40-bit and 64-bit WEP encryption are the same thing - 40-bit devices can communicate with 64-bit devices.)
While there is no extra performance cost to encrypting the longer key, there is a cost to transmitting the extra data over the network. 128-bit security is not much more difficult than 64-bit to crack, so if you are concerned about performance, consider using 64-bit. If you're very concerned about security, use WPA, which replaces WEP with a protocol that is - given current technology - impossible to crack. There's a good overview in What's New in Security: WPA (Wi-Fi Protected Access).
The WEP concept of passphrase is introduced so that you do not have to enter complicated strings for keys by hand. The passphrase you enter is converted into complicated keys. Choose passphrases with the same care you would important passwords.
  • With 128-bit encryption, you need to enter a passphrase to generate each key.
  • All four keys must be specified, because WEP switches between them to make your traffic more difficult to break.
  • All devices within your LAN must use the same passphrases (i.e., the same keys).
WEP is not necessary if you have a gaming console such as PlayStation or Xbox, and there are no other computers on the network.
Read Instructions on how to Configure Wireless Security (WEP/WPA/Access list). Instructions are also included on the User Manuals and Reference Manuals for wireless products (available on the Product page on this site as downloads).
Doc ID: N100684.asp April 7, 2003
Feb 01, 2011 | Computers & Internet
Hpj4680 will not print after adding wep pw
Cant you use WPA2, wep is very weak and should never be used if you have the option to use WPA.
If you have used WPA2 security ( you choose the password )
and the printer is asking for a wep key ( the router generates a long key , you dont choose it).
That will be the reason you can't connect, if the printer cant be changed to WPA, you only have the option to log on to the router and change security to WEP, which i would not recommend
Jul 22, 2010 | HP J4680 Office Jet All-In-One Printer
Installing HP Officejet 6000 on Wireless Secured Network+ WEP key
I hate it when developers do stupid stuff like that. Its like they work overtime to make it harder for people.
Mar 11, 2010 | HP Officejet 6000 All-In-One InkJet...
How do you set a password for the wireless router after installation
I have a belkin router as well. in your address bar in you internet browqser (internet explorer, netscape, etc.) type in http://192.168.2.1 This will bring up your router configuration page. Go to the section that lets you set a password. (It is probably under wireless security) and set a password or "network key". If it asks what kind of security you want (eg. WPA, WEP, etc.) I would simply choose WPA. It is not the strongest security, but it is the easiest to setup and unless you live in a densely populated area ( e.g. new york apartment) it is all you should ever need. If you have any questions feel free to ask me at lilchicken_dean2@yahoo.com Hope I could help!
Nov 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Just installing for wireless but does not pick up network ,wireless light is on. Thanks
Try this :
Press the setup button on the printer;
Goto network setup
Run the wireless setup wizard
It will ask for the WEP or WPA key (Wireless security key)
If you don't have it contact the router company other can check from the EWS page ; put the default gateway(ip address ) in the address bar fo IE and check for the wireless settings; Even if you dont get it check the Below given Link for The network diagnostic utility ; Download it on your desktop and run it ; it will give the WEP/WPA key
Network Diagnostic Utility:
ftp://ftp.hp.com/pub/printers/ndu/
Click on HPHNDU..
Save it to your desktop
Check the WEP/WPA key
Put it in the printer
Select done it will get connected to the network
for further help can check the link given below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01491627&cc=us&lc=en&dlc=en&product=3560280
Oct 25, 2009 | HP Photosmart C6380 All-In-One InkJet...
Trying to connect Epson stylus photo PX700W to aol wireless network. Am being asked for WEP/WPA info and security codes etc.
The wireless network is protected with a WEP/WPA security key. You need to get this key from AOL with our membership.
Oct 19, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Hp c7200 can't connect to wireless network
Try this :
Goto network setup
Put it in the printer select Done
It will get connected to the network;
Check the Link: (for wireless installation)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01084503&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 15, 2009 | HP Office Equipment & Supplies
Wireless connections won't connect!!!!
make sure if your using WEP or WPA or NONE if the wireless router has a security like WEP or WPA make sure you enter the right WEP KEY or WPA key if ask on your computer take a look for your wireless router setting and wireless setting on your computer meets and same..
or
might be on your ADSL or what ever line you have try contact your ADSL hotline or what ever Line you use might be they had connection problem
or
try using LAN if working. if not your ADSL Line or what ever Line you use is the problem
Hope it help you out ^_^
Jul 03, 2009 | Velocity Micro NoteMagix x30 Laptop
Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
718 people viewed this question
Top Digital Products Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alan Rothery
Alun Cox
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
