How do I use the 4 GB Sd HC insertable card ? I would like to use it for photos,music or as an additional hard drive. Where do I begin to undrstand how to operate this card? Thank you.
  • 341 Answers
First off, you will need a card reader that is capable of reading SD HC cards. You may have one in your computer already or you may have or can buy a USB card reader. The H.D interface is not that new so most readers have the ability to read these cards.Usage is simple.Just plug in the card reader, if it is not already part of your computer, and Windows will install the needed drivers. Put the card in the appropriate slot and your computer will assign it a drive letter.Then just copy from one location of your computer and paste it to your card.You can also "drag and drop" if you wish to.Do not defrag or format the card as this is no required and besides, if you do it really shortens the life of the card.If I left something out just post again.
Posted on Dec 26, 2008
Duracell pro photo 16 gb sd card Beeps when
What make and model camera? Bear in mind that your 16GB card is actually an SDHC card, not an SD card. Some older cameras and card readers will only handle SD cards (2GB or smaller) and not the higher-capacity SDHC cards.
Sep 25, 2013 | Duracell Pro Photo 200X Secure Digital Hc...
Tip
Computer Cannot read my SD Card
STOP SD MEMORY CARDS ARE NOT ALL THE SAME !This is a very common issue as of late because of the fairly recent addition to the market place with the "HC" and "XD" Cards. I have found most computer older than 2008 wont read HC and XD cards however I'm sure there are USB card readers that can fill this gap available at your local pc shop. Please look Carefully at these different formats Standard SD: 1 MB to 4 GB readable by almost all computers most often up to 2GB rarely up to 4GB 6468175.jpg
SDHC: 4 GB to 32 GB Most older Computers Cannot read the the HC format, good however for NEWER devices such as camera's, video cameras and recent phones (my cannon powershot S80 will NOT read HC format, nor will my 2007 laptop.)
SDXC: 32 GB to 2 TiB same limitations as above, Great cards for Digital Video Camera though!
here is a wikipedia note "Changes to the interface of the established format have made some older devices designed for standard SD cards (≤4 GB) unable to handle newer formats such as SDHC (≥4 GB). All SD cards have the same physical shape, which causes confusion for many consumers"
So.. in closing MAKE SURE your device supports HC and or XC before your purchase one! Also be aware that most of these cards have a lock switch on them to write protect the data, located on the side of the card. It MUST be in the Unlocked position to operate normally. Hope this helps someone out there. please use the thumbs up if it clears up anything for you! Gurvy
on Aug 31, 2010 | Computers & Internet
Recover deleted photos using mac
have you lost your photos on your memory card/USB drive?
If you appear to be a Mac user, just try this Photo Recovery app. It can nimbly recover deleted photo files, music sources and video clips from Mac hard disk drive and memory devices containing USB Drive and SD card. http://www.leawo.org/photo-recovery-mac/
Simply insert the card to your Mac and run the photo recovery app. The software may help you scan the card and then show you files it has found. Choose the pics you want to get back and hit the "Recover" button to start.
Jul 15, 2013 | SanDisk Ultra Electronics - Others
Remove write protection from sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 17, 2013 | SanDisk Micro Sd Hc Card 16gb San Disk 16...
FORMATEAR MICRO SD HC 8GB
Depending on your laptop, 8 GB SD cards may not work. That said, insert the SD card, open Computer, right click on the SD Card icon, format.
Dec 13, 2012 | Toshiba Computers & Internet
My mustek dv5500 was not capturing photos and videos
Hi Siva,
The most likely issue with your camcorder is the SD card that you're using. Please remove the SD card and check if it is labeled as a SD HC card, as the Mustek DV5500 is not compatible with these newer revisions. You can try to fix this problem by using a regular SD card (they are all below 4 GB in size and do not have HC written on them).
Oct 11, 2011 | HP Photosmart R707 Digital Camera
How do i put music on my sansdisk micro sd memory card for my phone?
If you have Micro SD Card reader then insert the SD card in that reader and place it in USB. So that you will get an additional drive in My Computer. Then go to the new drive there you can see SOUNDS folder open and paste the songs. Remove and insert into Mobile phone and update the Music Library. Now play the music..
Thanks & Regards Nandu :)
Dec 27, 2009 | LG CHOCOLATE VX8500 Cellular Phone
No sound when playing the video off my sd card
i imported my video files off my sandisk 8 gb micro sd hc card they show up in windows media player and play fine but cant get any sound out of any of them
Nov 19, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sd card issue
According to the manufacturer specs, only the mmc and sd flash protocols are supported. The sd hc protocol is not supported. There are some 4 gb sd cards that were produced before the sd hc format was produced (starting at a 4 gb capacity). Try a few different manufacturers for the 4 gb sd card.
Mar 19, 2009 | Casio Cameras
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
