Question about StarTech.com StarView SV211K 2-port KVM Switch
Starview 3 hi i have downloaded new version for starview 3 onto my computer but cant transfer to the box i have all leeds but no good please help
  • 827 Answers
This guide is intended for use with the Eurovox but the equipment required is the same for flashing other boxes. The only differences will be with the relevant box firmware and its loader software.
WHAT YOU NEED:
1. Null Modem Cable ( available from here )
2. Serial to USB Adaptor ( available from here
The above adaptor assumes that you want to use a laptop to do the job; as most recent laptops do not have a serial port, you must purchase the adaptor.
The Serial to USB adaptor will come with a drivers disk. So install this before we go any further and follow on screen instructions.
Connect the adaptor to the USB port on the laptop. Connect one end of the the Null Modem cable to the Adaptor and the other to the serial port on the Eurovox.
Provided you have downloaded the correct version, proceed:
The file will have to be extracted. Use winzip or winrar for this procedure ( Very easy )
Ensure the Box is powered on. You can leave connected to the TV if you choose.
If you have your channels set up in Favourites we will back them up before flashing, although in some instances, the new update will not affect stored channels if your firmware is not too dated.
Anyway, go to the file which you extracted and start the application. ( It will be named UFL_MaxV_Kuro V........ ) Your first action will be to upload channel data. Select a name and a location for the file and save it. It is at this point you will be alerted if the box has connected with the PC. If it has not, do the following:
Go to Desktop / Right click" My Computer" / Select Properties / Hardware / Device Manager / Ports & Com Ports. Now select the next option to appear , in my case it's prolific serial to com port. Now select Port settings / Advanced / Change com port to 1,2,3 or 4 / OK / Exit .
Go back to the loader screen and you should now be able to communicate with the box.
Following channel data backup, you must now download the firmware to the box. Again, it is indicated on the screen and very easy to do. Once initiated, the box will display DNLD message and a progress bar will appear on the laptop screen. Allow to complete fully ! Do not disconnect until UPDATE SUCCESSFUL message appears on the screen. This can, in some cases, be 30seconds after 100% has been reached on the progress bar.
Finally, download your channel data and the operation is complete.
Now:
factory reset,
re scan,
go into the menu where you click on the set default key
switch on Emu
exit 3 times
wait for code to update
needs to be done after you have applied the fix,
And if that doesn't work put on Sky or Setanta orParamount+1 for a second, certain channels kickstart the process.
Hope this helps
Chris (ziraffa)
http://www.bubblecableboxes.com/forum/showthread.php?t=223
http://forums.afterdawn.com/thread_view.cfm/722659
Posted on Dec 27, 2008
Hi there, wondering if you can help... starview box cant pick up channels any more... could u update the codes at all please?? many thanks
If your starview WAS working recently, then it will probably be the switch to Nagravision 3 in your area.
It coming to everyone, and when it does all the boxes will be useless.
check here....
http://www.articlesbase.com/gadgets-and-gizmos-articles/nagravision-3-fix-927130.html
Aug 09, 2010 | StarTech.com StarView SV211K 2-port KVM...
Need new codes for star view box super on virgin/ntl
this box updates automatically. virgin have found a way to cut the signal off. you can press menu then numbers 1570 and go onto nagravision menu and it will tell you how to enter the code.
if you can't get this menu then you havent got the right firmware in the box. hope this helps.
Dec 20, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Eurovox codes
anyone got codes 4 eurovox in leeds please
Jul 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost channels and advise needed
Hi, I dont know how good you are with computers, but you can get a programmer, and do your own card, your other options are getting a new box, like a starview, you would just unplug your box, plug in the starview box, but then you would have to download software for your box, some people sell boxes with software, and when codes change, you can update it yourself, hope you can understand this.
good luck
May 27, 2009 | StarTech.com StarView SV211K 2-port KVM...
My starview 3 box codes keeps going to ff
Press menu..then type in 1570..this will open another menu..go to default and press the default key..then press back..and go into nagravision you should be able now to find your provider..select that and enter your 00 code and store then change to 01 and enter that code..store and exit..make sure your emu key is on it's below the default key..then exit and all should work.
Good luck
Gord
Mar 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Ntl star box gone off has anyone got new codes yet
hi try these
00- b0 b8 4f 04 e6 5f 87 80
01- a3 eb ec 07 d6 49 d2 eb
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Update starview box
hi m8. there is a firmware you can Install I believe from your computer to your Box. I don't know al the details though.
Here are the 2 codes already changed today in case you have friends who need them. My pleasure trying to help with codes, I will post them on fixya when I get them.
C & W. 5C 01 00= DC 74 43 28 B6 B9 96 37 (NEW)
01= 36 69 21 D4 AE 14 A5 D1 (NEW)
NTL UK 54 01 KEY 00 = FE E3 C5 8D 05 B4 0B 4D (NEW)
KEY 01 = 78 AD 2A 3F 8F 2D 1B 9D (NEW)
Jul 29, 2008 | StarTech.com StarView SV431USB 4-port KVM...
Need todays starview codes
i want a code for my eurovox box please i live in preston area
Jul 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cant find the right driver for my version of the mither board..
The revision number should make no difference. Try the ones that you found and see if that works. It always has for me.
Jun 26, 2008 | Asrock K7VM2 Motherboard
StarTech.com StarView SV211K 2-port KVM Switch Logo
188 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
