Question about Smeg FAB32 Bottom Freezer Refrigerator
Freezer problems Hi i have a SMEG FAB32 bottom freezer refrigerator. The freezer has suddenly stopped working. It is 15 months old an is no longer under warranty. Please help.
We have the same fridge, yesterday our electricity felt out several times. After soms hours I noticed a temperaturedrop in the freezer so I guess this one gave up.
I did the check mentioned above. There are 2 compressors. If you look straight at the back of the fridge the left one seems to be cold, the right one is slightly hot so I presume this is the one from the fridge?
If so it seems we have a modulefault. Does anyone know how to fix it and how much it would cost?
Thanks in advance for your help.
Posted on May 20, 2010
    President:
  • 1,462 Answers
Remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
Posted on Apr 16, 2007
SMEG fridge freezer, freezer door was left open and it defrosted. we have turned the applience on again freezer is contantly triping and it is not working. red light is on constantly. please help
the relay is timing out this was caused by over run try turning off for 1 hr to let it settle and decompress if it does the same fit a new relay and try if that does not work it meens the compressor has gone expensive repair
Nov 25, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
The fridge is not cold enough although the freezer seems to work
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2010 | Smeg FAB32 Bottom Freezer Refrigerator
My MayTag refrigerator don't work, but it is on Maximum. The freezer works, and everything works, also the little fan in the freezer,it also works. I need any assitance for problem.
Check all coils for dirt and hair build up.
They can be cleaned with a soft brush and a vacuum.
Some are on the back of the fridge and some are on the bottom. Without proper air flow the heat cannot disapate very well. Check the vent holes inside the refridgerator side to see if something is in the way.
The freezer sends the cold air to the refridgerator through these vent holes.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Widths
no
what part of the world do you live as there is other manufactures
Apr 02, 2008 | Smeg FAB32 Bottom Freezer Refrigerator
Fab32 ps4 smeg
Is the freezer compressor running? The sub zero's have dual compressors, maybe one failed. How about the condensor coil, is it clean?
Dec 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Leaking Fridge
you may have a faulty defrost timer, best consult a local dom apps store.
May 17, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerator doesn't work but freezer does
Sounds like the little evap. fan on the rear of the freezer section isn't blowing cold air up to the refer section.
Aug 28, 2006 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg FAB32 Bottom Freezer Refrigerator Logo
415 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Charles T Nevin
Charles T Nevin
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
