Question about Sony KV-32S20 32" TV
Wrong plug in voltage
My sony KV 32s20 32" tv was pluged in to a 220vlts outlet , its a 110volts only. the fuse is ok , what could be the problem or what other parts i should replace for my tv to work. need help pls... thanks...
  • morfeus_org Dec 27, 2008
    thanks for giving time to read my problem.....
    witch resistor? str....?
    Problem Solver:
  • 18 Answers
Resister or str
Posted on Dec 26, 2008
How can i solve sony tv model kv-29fx65e with no problem?
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 01, 2015 | Sony Televison & Video
Kv-27s20 fuse
if you open the back,follow the cord..theres the fuse. replace it,dont put the back on,plug it in...fuse blows right then. bad power supply.
check on our site for parts and TVs http://www.shopjimmy.com/
Sep 06, 2012 | Sony KV-27S20 27" TV
We have a Sony KV-35V36 TV. Will watching TV and the power just went off. We get no power all all anymore. How do you ge the the fuse on this TV.
The fuse is inside the chassis and likely soldered. Unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if that has reset it.
Is the outlet good, or did the power outage trip the breaker?
Apr 22, 2011 | Sony KV-35V36 35" TV
Sony KV- 20FV12 get no signal on screen. Same cable outlet works on other TV as a test. Cable ON in menu. Auto Set search produces search but still no signal.
Hello
If auto search is going on smoothly, and there is no stations on air is memorized, and display no signal, there are tow possibilities. The first one is antenna is not connected properly. Check the antenna connection for firm. The second one is tuner fault. If the tuner inside the tV is faulty, or it does not gets proper voltage to work, this type of fault land display will see on screen. Check if proper voltages are comming to the tuner section in circuit board. If voltages are ok, and still there is no signal display, just check it with external video input. That is, connect it to any dvd or cd with AV connector, and set the TV to AV mode and play a disc. If there is picture, the video side of your TV is OK. If not, Video-chroma-RF jungle IC is faulty, and not the tuner. OK.
Feb 03, 2011 | Sony KV-20FV12 20" TV
High voltage shutdown
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-27S42 27" TV
No pix. Red LED blinks 2 times. ( sony KV-24FS-100 TVset. )
this is your over current protection B+, there is a short in the power supply of many of the circuits,fuse,diode,etc, check these carefuly with ohm meter....if fuse is open,only replace it with the same rating,make sure tv is not pluged into outlet...if you need to replace parts,use a desoldering iron,to **** off the solder at pin hole of the part being removed from under side of board also look for burnt spots,then you need wire wick to remove and clean in and the pin hole. reinstall is reverce order,,maker sure you make a good connection,and not over solder it ...keep it clean.hope this helps...........
Feb 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
May 10, 2009 | Sony KV-32FS12 32" TV
Sony tv keeps turning off
first make sure that the plug of the tv-device is well pluged-in and the voltage in your home is normal.if all this, is ok ,enter in the menu and check the status of `timer sleep`(if `on `than turn it `off`)
Jun 06, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
This TV worked very will until the past two weeks when it refused to start up
Any sound? If so, it could be a bad display or high-voltage or associated problem.
No sound and no picture could be a bad line cord, power switch, blown fuse or AC problem.
In this case, make sure it is plugged into the ac outlet and the ac outlet is getting power by plugging in a lamp that is known to work into the outlet. If it does not light, then ther is no ac power at the outlet and you have a bad fuse or tripped circuit breaker (most likely) or (less likely) a faulty outlet or break in the house wiring.
Good luck! :)
Mar 08, 2008 | Sony KV-36XBR400 36" TV
Televison & Video Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
