Question about Hoover F7220900 SteamVac V2 Upright Vacuum
My Hoover steamvac brushes do not turn
I have checked the filter and other common problem that the manuel suggest. Thank you in advance for your help!
Allen from Missouri
  • 1 more comment
  • Big A's Auto Repair
    Big A's Auto Repair Dec 28, 2008
    I am posting this in hopes that sunny16 will see it, I was to quick to rate him he actually let me in the right direction to repair my vacuum cleaner and now it is fixed. Is there anyway to change the rating too FixYa for that chat session. If not sorry about that sunny16. You are very knowledgeable in you field.
  • jmnla Feb 12, 2009
    Brushes on my hoover Mod# F7431900 do not turn
  • jmwilkerson Feb 15, 2009
    my brushes won't spin and i cleaned the filter.
    Scholar:
  • 57 Answers
There is a plastic shaft on the back of the block brush (spin scrubbers), these wear out or break. You may need to replace the block brush. Or if the shaft is not broken it could also be the Turbine Gear. This is what the block brush shaft goes into. You can get access to it by taking off the hood. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F72XX Link
http://www.usavacuum.com/Hoover-Steamvac-s/110.htm
Posted on Feb 26, 2010
  • usavacuum Mar 01, 2010
    The brushes are turning by an air driven turbine. The turbine has a
    pivot bushing made of steel inside of it that gets rusty because of the
    water that is running through it. You can find a genuine hoover replacement part by following the link
    above
How do you connect the brush
I've done a previous post on how to install the brushes on your Hoover SteamVac, please check out the link below:
How To Install the Brush Block for Hoover SteamVac
Hopefully this helped you. Please be sure to rate it helpful if this was able to answer you question.
Thank you,
Chris JonesGoVacuum
Sep 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac brushes aren't turning ...
Sometimes this speed knob can be really stuck on there. Even if you were to break off the part that the knob sits onto, this part is actually part of the turbine assembly, and the new turbine assembly would have that prong that the button sits on.
As long as you have the screwdriver underneath of the knob, I wouldn't worry to much about putting too much pressure on it.
Let me know if you still have any questions, I'll be happy to help you figure it out.
If you found this helpful, please be so kind to rate the repair that I wrote, or leave feedback.
Thank you,
Chris Jones
GoVacuum.com
May 27, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
Why don't the brushes go round on my Hoover carpet cleaner
HI There,
Here's a link to a Fixya repair solution that I recently did on this exact problem. It's actually a fairly common problem. The second link is to another solution that will walk you through step by step how to replace the turbine assembly if you find out this is what the problem is.
How to Diagnosis a Hoover steamvac spinscrub brushes stop spinning:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
How to replace the Brush Turbine Gear if you find out this is what has gone bad:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you need to purchase a new spinscrub brush block, here's a direct link to the exact brush block that's used in your model:
Hoover SteamVac Brush Block - 5 Brushes Part # 48437022
If you have any follow up questions, please don't hesitate to ask them by using the comment form here on the Fixya repair page.
Thank you,
Chris Jones
GoVacuum.com
May 12, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning brushes will not turn. I have cleaned the filter
Hi There,
Here's how you can fix the problem of your brushes not spinning on your Hoover SteamVac:
Hope that helps you,
Chris Jones
goVacuum.com
Apr 25, 2010 | Hoover F7431-900 SteamVac Vacuum
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7220900 Brushes don't turn
First off make sure that the filter inside the dirty water tank has a gap from the top of the cover to the top of the filter. The must comment problem when the brushes dom't turn is either the brush block, the shaft that goes into the turbinge broke off. If brush block is ok, then the turbine is bad and will have to be replaced.
Dec 16, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F7210-900 SteamVac
Before you take it back, check the filter inside the lid of the recovery tank, if it is all of the way to the top, it will cause problems, it needs a 1/4 in. gap from the top. Might be also that the plunger in the handle is pushing all of the way down so as to release the water.
Nov 22, 2007 | Hoover F7210-900 SteamVac V2 Upright...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
215 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
