Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Blinking green light on mitisubishi ws55813
Held down menu button for 10 sec nothing, hit reset nothing, unplugged and replugged in nothing help. THe tv is not used much, becasue after use of 6 months i got burn in and had to placed all lamps to the tune of !,200.00 Please help
I can stop the blinking green light on mitisubisshi ws55813
Posted on Sep 08, 2009
  • 126 Answers
Error code. return to supplier. Possibly power supply
Posted on Dec 25, 2008
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Mitsubishi ws55813 picture turning off
The model indicated has a self check feature.
If turned on and green power light comes on and a few seconds later goes out:
On front of set press and hold both the menu and input(device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
Let me know what error code you find.
If you unplugged the set--you will have to plug it back and attempt to turn it on--unplugging set clears the error buffer.
May 16, 2012 | Televison & Video
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
Printer problem
Un plug it from the wall. During this time go to your printer spool directory. Normally in windows this is:
C:\WINDOWS\System32\Spool
or C:\WINDOWS\System\Spool
You can always do a search for a folder called 'Spool' if you cannot find it. It will be in a similar directory to the above examples. Select all the files in the Spool folder and delete them.
Now turn the printer back on and wait for any lights to stop flashing before retrying printing. If they continue to blink, its either got a hardware fault or the ink is low
Jul 07, 2009 | HP Color Laser 2550N Printer
Miti 1080 sereies tv won't turn back on
Befor thinking the worst, it may just be a tactile switch, probly the vol. down button switch on the front panel of the set. When you unplug the set and replug it again, does the green LED stop blinking after 20 sec. or so?
If the Green LED does not stop blinking you are talking a major repais on the Main Chasi Assy.
Hope this helps,
Skyassoc
May 26, 2009 | Mitsubishi WD-52725 52". Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Blinking timer light nothing works
have you tried the menu and device buttons held in together to activate the led error code feature? Let me know the error code.
Jul 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Timer light
does the light blink for more than 70 secounds? if it does go off after 70 seounds the keyboard lockout feature may be engages to unlock press and hold menu on keyboard for 10 secounds. If the set contiunes to blink after 70 secound after plug in then you maye have power issues or a possible bad digital board
Nov 04, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
