Question about HP Pavilion dv9000z Notebook
Lost drive letter on computer
I lost my drive letter when I open the computer window that shows my drives. My C drive is there but not my second hard drive letter.
This only is when I log on to xp. When I log on to vista I see both drive letters.
Thnaks,
Mike
SACBAKER@yahoo.com
    Scholar:
  • 176 Answers
Go in control panel - performance and maintanance - administrative tools - computer management- storage - disk management ! and there u can set all u;re drive letters and more ...
Posted on Dec 25, 2008
My computer will not pick up my drive when i put it in
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 20, 2011 | Computers & Internet
Tip
Using Windows Disk Management Utility to Manage Internal and External Disks
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a “Drive” and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”)
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter “C”.) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters “F” or “G”. In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
on Jan 29, 2010 | Computers & Internet
Where is sandisk repair centre in banglore? my 8 gb pen drive is not able to access by the computer and it is not getting formated
You can work at formatting you cruzer using windows disk management utility. The instructions are listed below. This may help you avoid going to the repair center. If your computer does not see the flash drive and you see no activity, the cruzer may failed. These 2 gb flash drives are really cheaper to replace than to repair in todays market. Also here is a link to Scandisk support showing directions and images refering the use of disk management.
http://kb.sandisk.com/app/answers/detail/a_id/10/sno/0
Here are the directions:
- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Feb 11, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I purchased two identical hard drives. (MyBook Essentials 2T) The first one works fine, the second, loads the driver and says it is now ready to use, but when I look for it, it is not there. (Show...
What may be happening is it's conflicting drive letters.
Try this.. Plug in the drive. Right click on My Computer, choose Manage. Go to Disk Management under Storage.
Look for the WD drive there, it may have no drive letter associated with it. That would be the problem. Right click on the drive entry and choose Change Drive letter. Pick a Letter.
Exit out and open windows explorer and the drive should now show up.
Jan 28, 2011 | Western Digital My Book Essential...
My sea gate external hard drive can not open and my computer can not read it
Using the windows disk management utility. This will tell you if the hard drive is connecting to the computer or if it is a hardware problem. Sometimes, power cycling the external and restarting the computer will help. Below are the directions for using this utility:
A menu will open
Chose "Manage"
Please remember to post positive feedback if this solution was helpful. If not, please let me know and I will assist your further.
Thank You,
Brian
Jan 25, 2011 | Seagate FreeAgent Go 500 GB USB Hard Drive
New 1TB My Book Essentials ext drive not recognized by laptop
There are times when external drives need to be inialized and formatted before they can be recognized by a computer. There are other times when the drive letter that the external is looking for is already being used and it does not show up.
You can use the disk management utility to initialize, format or change drive letters around. You do not want to change your C drive, also usually called drive 0. Below are directions for accessing and utilizing this tool:
A menu will open
Chose "Manage"
This should get you to see your external. If you don
Jan 16, 2011 | Western Digital My Book Essential 1TB...
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
A menu will open
Chose "Manage"
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
How to unlock a sandisk cruzer usb flash card 16 gb
If you cannot open your usb drive, you will need to open your drive management. Sometimes, drive letters that the usb drive looks for, usually F, G or H, are taken by other drives. You can change drive letters on other network drives to different letters, therefore, allowing the usb drive to access the letters it is looking for, and effectively, unlocking it. Below are directions on using the Disk management utility in windows:
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility. Also, drive '0' is usually your main hard drive.
A menu will open
Chose "Manage"
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Jan 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My western digital dosent get detected, whenever i connect the device a new hardware found sound comes and nothing comes in my computer, i tried restarting nd olso tried to connect the device on other...
sometimes drives need to be initiallized when they are connected I will give you instructions to use the Manage Feature of windows to manage your drives. The instructions are as below:
If you cannot see the drive using the disk management utility, then you need to check to be sure the drive is not malfunctioning and also check your connection cable to be sure it is not the problem.
I hope this is helpful!!
Brian
Using Disk Management Utility
#2- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
Dec 23, 2010 | Western Digital 320GB MyBook External USB...
CANT FIND IT ON MY COMPUTER
have u insert it? check it at first in device manager then inform is it showing or nt?
Mar 24, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
HP Pavilion dv9000z Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
