Question about Bosch Exxcel WFX 145S Front Load Washer
Washer has key symbol on display unit permanently
My bosch has the key symbol permanently on the display unit and I can't find my instruction book.Dont' know how to rectify it or what I am supposed to be looking for.
  • 3 more comments
  • bilton col Apr 15, 2007
    Thank you very much for the reply. I have been able to rectify it. Had spent hour searching for manuals etc from Bosch.
    thanks again.
  • david0608 Jun 08, 2008
    hello, just wanted to thank the good people on the web who share info effectively when manuals and other official support not so readily available. I had the same problem today, and been able to sort it out quickly only because of your posting. bosch support is pain. thank you again.
  • NikkiRod Jan 12, 2009
    My washing machine has the key sign on the display unit and I can't find my manual. Can anyone help me with this?
  • Anonymous Mar 27, 2014
    displaying a key symbol clasic 7
  • Anonymous Mar 28, 2014
    Key symbol flashing on digital display
  • 944 Answers
Go to this link (or copy and paste it into your browser if it doesn't post as a link); https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM third from the bottom is your user manual, second from the bottom is the quick reference guide. the key symbol is the childproof lock function - to activate or deactivate it press the start button for about 4 seconds during a cycle - check page 32 of the user manual for a more detailed description. Hope this helps - please ask again if not :)
Posted on Apr 15, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Apr 15, 2007
    you're welcome
  • annieshere Jan 09, 2011
    I had the same problem today, thought I had broken the whole machine. Renting the flat, so no manuals here ;). Thanks so much for teh solution!
    xx
    Anne form Scotland
SOURCE:
I have a bosch clasixx machine there is a symbol like a key on timer and machine wont start how do i get rid of this
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Washing Machines
Lock Symbol staying on
Hello, welcome to FixYa.
On most bosch of your class this is how you work it on & off.
Thank you for visiting "fixya" for your washer solution inquiry.
macmarkus :)
Sep 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch classixx 6 1200 express is showing a key symbol in the LED - when I switch on the washing time goes back to 0 and the alert sounds and I cant start the wash I dont know how to switch the key...
macmarkus :)
Aug 19, 2010 | Bosch Washing Machines
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Child lock flashing
Hello Lynn, Welcome to fixya. The key symbol indicates the washer has somehow been placed in the "child lock" mode, hence it won't allow any program to over-ride it. Here's what to do to deactivate it... 1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display ) 2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display. 3) Finally by pressing the start/pause button the key symbol should disappear confirming you have successfully exited the child lock program. That is the procedure for the child lock function on your Bosch washer and should solve your problem. Let me know if this was helpful to you or not, if so please take a second and rate it accordingly. Thank you for visiting "fixya" for your washer solution inquiry. good luck going forward. macmarkus :)
Jun 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
There is a key symbol and I cannot start my next load
Hello and welcome to Fixya.
You`re likely right on about inadvertently locking out the controls. Your washer has a "child lock" program and I suspect that has been activated.
If this indeed was the issue preventing you from operating the washer you should now be free to select any cycle and carry on.
macmarkus :)
May 07, 2010 | Bosch Classixx WFL 2066 Front Load Washer
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch Exxcel WFX 145S Front Load Washer Logo
921 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
