Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
I cannot get my psp slim, lite to play on my tv.
I purchased one of composite leads that is designed to connect a psp lite to my HD TV, in order to watch umd movies and play umd games. I've tried everything possible without any luck, could you please tell me how to get connected? The cable is titled component cable for psp slim.
Regards
Ash.
  • Michael Badgett May 11, 2010
    what exactly did you try
    New Friend:
MY PROBLEM IS WHEN I PLUG ALL THE CABLE. "CONNECT AV CABLE" SOMEONE TOLD ME MY PSP2000 IS BROKEN WHAT I MEAN IS TH AV SOCKET OF THE PSP
Posted on Dec 09, 2013
  • 59 Answers
Connecting the psp to tv is easy first connect the cable from psp to the tv then open your psp and tv now in your psp select "connected display setting" then press x then
make sure this is the settings
>>tv type: 16:9
>>Component/D-terminal output: Progressive
then select "switch video output"
you can even play games in your HD TV when you do this settings. send us a message for more info
Posted on Feb 13, 2010
  • Bash Vierneza
    Bash Vierneza Dec 09, 2013
    I ALWAYS TRIED THIS ONE, BUT NO LUCK. MY SISTER TOLD ME MAYBE MY PSP IS BROKEN T_T
  • 35 Answers
Make sure that the wired are in the right holes, in the right area
Posted on Aug 08, 2009
  • 25 Answers
    Problem Solver:
  • 7 Answers
You need specific cords for an hdtv there are different cords for hd and regular
Posted on Jun 25, 2009
  • 38 Answers
Connect the psp side to the bottom right. Connect the tv side to the corresponding input colors. Your tv needs to have progressive scan and the right inputs.
Posted on Mar 14, 2009
How to connect a sony playstation portable psp to a tv to play the video games?
Well First you need a special video cord for the psp and i beleive only the 2000 seires [slims] can do it, also i think the tv has to be HD cords, i think cause my friend tryed to use a standrad tv and it didnt work so its might be the component cords, red blue green, then two audio red and white gl
Jan 06, 2010 | Sony PlayStation Portable (PSP) Console
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
How do i play my psp on my tv is a psp1001 ?
TV support for the PSP was not introduced until the Slim and Lite version, AKA PSP-2001. They added a video-out cable through the connectors next to the headphone jack. Sorry.
Sep 25, 2009 | Sony PlayStation Portable (PSP) Console
When i connect psp to tv(hd) the screen apears red. Pls help.
It sounds like either the cables are reversed, loose, or possibly bad. This is what happens when a cable connection is not "solid". Please make sure all the cables are attached securely and in the correct order, if they are you may need to replace the cable. If it still happens with a new cable, it is probably the input on your TV that has an issue.
Aug 30, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP AV component cable - no picture
Try setting your TV to AV1 setting to see if this fixes the problem. Hope this helps.
Aug 19, 2009 | Video Game Consoles & Games
I WANT TO FINE THE WAY TO CONNECT THE CABLES FROM PSP TO TV.
First you're going to need a slim psp, if you have it then you just plug the cables to the right places. To play games on your tv you need a tv with progressive scan and component inputs.
Mar 11, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp connection to the TV
The cables you speak of is called component cables. They only go into color coded connection in the back of your tv. The best way is to look behind your television and more than likely there should be rows of either three or five connection and or markings saying RCA or Component connection. What your looking for is component.
Just to give you some info:
The cables you own will play vids, music, and games. But in order for the games to work you must have a HD TV.
If you see RCA jacks for your psp 2000 (slim) or 3000 (lite) than the only things will work is vids, & music (on any TV so long there is a RCA connection doesn't have to be HD).
Hope that helps.
Jan 23, 2009 | Sony PlayStation Portable (PSP) Console
Sony psp slim component cable trouble
Okay the cables you bought they have five plugs. I assuming your tv doesn't have component input only RCA connections (RED, WHITE, YELLOW). SO in that case you bought the wrong jacks. You may want to keep them anyway if you upgrade your tv. Because these "component" cables is the only way you can play video games on the big screen and also has to be hd, but it also will be able to play music, view pics, and watch videos. But that's a different subject.
You need to buy RCA cables for your slim. Keep in mind though you will only be able to watch movies, pics, and music. You won't be able to play video games. Once you have those it's not hard to connect. All you do is from the XMB menu go to display settings click on "switch video output" and it should connect from there. Any more problems please feel free to ask.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
What is the difference between psp 2000 and psp 3000?
PSP Slim and Lite (2000 series)
33% lighter than the original
19% thinner than the original
The redesign also features composite TV output, supports charging via USB, double the onboard RAM (32 MB to 64 MB), and has a brighter screen.
catches UMD data for shorter loading times
PSP-3000
Its based on the Slim & Lite (PSP-2000) design
PSP-3000 features an improved LCD screen, a built-in microphone, and expanded video-out.
The LCD screen features a higher contrast ratio, shorter response time, and wider color gamut, as well as anti-reflective technology for improved visibility in well-lit environments.
Expanded video-out capability allows gameplay video to be output in interlaced format.
Unless your going to be using a mic, in well lit environments, and are really bothered about pic quality go for Slim&Lite as it is cheaper.
Nov 17, 2008 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
241 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
