Question about Microsoft Flight Simulator 2002 Standard for Windows
Can't control Microsoft Flight Simulator 2002 with yoke.
I am trying to us a CH Products yoke with Microsoft Flight Simulator 2002, but the yoke doesn't properly control the plane. I have contacted CH Products tech support and on the basis of their tests, they say the yoke is working properly. I have followed Microsoft's knowledge base instructions for remedying the symptoms I am experiencing, to no avail.
Hardware:
Shuttle motherboard
AMD Athlon 64x2 Dual Core Processor 5000+ 2.6 Ghz
2 GB RAM
NVIDIA GeForce 7025/NVIDIA nForce 630a embedded Display Adapter (I've confirmed that I am running the latest drivers)
O/S:
Windows XP Pro version 2002 Service Pack 3
Any help would be greatly appreciated.
  • 51 Answers
SOURCE: The tutorials in MS Flight Simulator X unexpectedly stop
this is Easy... so when he talks he tells you what to do as you go along so do
EXCATLY AS HE SAYS then he will keep going. Also Your Computer May Be old.
Posted on Feb 11, 2009
SOURCE: I have a problem when I try to install Flight
it has a error when you are bout to get one installing
Posted on Aug 05, 2009
  • 94 Answers
SOURCE: halo is running slow in vista here is my system
maybe your graphic card's video memory is too low... just buy another one or upgrade it
Posted on Nov 01, 2009
  • 13433 Answers
SOURCE: My Microsoft Flight Simulator 2000
Hi start off by re-installing the whole game. uninstall the game properly and then run it again from the disc, also make sure the cd's surface is clean, if the problem remain after that let me know and if you get any kind of error messages let me know also.
a possible workaround for the disc verification would be to bypass it.
Posted on Oct 30, 2010
sonicboomele
  • 1557 Answers
SOURCE: I uploaded Flight Simulator X and am now trying to
press the x button whislt holding down throtle
Posted on Mar 08, 2011
I have a simple problem with the SAITEK pro flight yoke. The LCD display is backlit, but BLANK. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LCD DISPL
If the LCD is not working then it is likely that required drivers are either not working or missing. Try downloading updated drivers from the Saitek website.
Nov 08, 2012 | Saitek Pro Flight Yoke System Flight...
Just purchased saitek yolk with throtle but its not working ,.tried calibration still does not work
I had a friend with exactly same issues, only he used a CH Flight Yoke system.
Calibration can be very tricky sometimes, and it has very often to do with how the configuration file has been set up.
You might have to rebuild your configuration file for your Flight Simulator before it will work properly.
However here is some hints for calibration fix from Saiteks UK support.
Maybe this can solve your problem, understanding how to make a valid configuration file for Flight Simulator.
http://www.saitek.com/uk/supp/yokefsx3.html
Good luck
Aug 24, 2011 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
I cannot create a flight on fs2004.when ever i go to fs2004 the system will shut down or go blank.
first all have you added any type of addon's like new airplanes
or scenery if you have then something there may be cousing your problem. if its an airplane go back remove that airplane. and try again
if all this fails you can reset flight sim 2004
go to Start then program files then microsoft games there you see microsoft flight simulator 2004 click on that then another box open up you see troubleshooting you notice in there rest to defaults
do not use this unless you wont reset it all to defaults settings. if this does not cure the problem then a reinstall of flight sim is needed. if you need any more help please ask
May 12, 2010 | Saitek Pro Flight Yoke System Flight...
On saitek yoke system it wont work on fsx *flight simulator x* if you can help thanks !!!!!!!!!!!!!!!!!!!!!!!
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Sep 07, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Microsoft Flight Simulator 2002 Standard for Windows Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
