posted by ITGuru on Apr 15, 2007
After upgrading my PC to Windows Vista I can no longer authenticate on to the StorStation. I am running a Windows 2000 PDC and I have the workgroup name on the FSV set to the same domain name. I have tried creating a new user but every time I try to connect I just keep getting "Logon Unsuccessful". It all worked fine under XP and nothing else has changed. I have also tried building another Vista Workstation and that won't authenticate either.
Any Ideas gratefully appreciated
Cheers
Andy
Comment by ITGuru, posted on Apr 23, 2007
Hi
cheers for trying to help, I dont think that the Server on my network has anything to do with the problem but I may be wrong, my reasoning behind this is that the Storstation uses its own set of users and passwords and is not windows based. I created users on the Storstation that are the same as the Domain users, this way under XP I never had to authenticate onto it as XP automatically submitted the current user logon information. I assume Vista also does this but just presents it in a different way that the Storstation doesn't like. My Vista version is Business.
Any thurther ideas gratefully recieved
Andy
Andy
A small additional thought....
Is it possible that because the Storstation only accepts usernames up to 8 characters that if Vista submits DOMAINNAME\Username that this is where the problem lies
Andy
Andy
Comment by ITGuru, posted on Nov 01, 2007
Hi ReverendFunk,
No i still have not found a sollution and only access the box from XP now.
Best Solution
posted on Apr 21, 2007
what version of vista are you using, this is a very important piece of information, vista home flavors are not very network friendly,I recommend that you keep using XP until a few service packs are out for vista. If your using ultimate then something else would be wrong, possibly a setting on the vista box, Im not real sure how vista's authentication works but if they changed it enough then it might require a compatiblity mode or something in order to authenticate with 2000/xp, but then again i could be wrong and vista might authenticate exactly the same way as 2000/xp, try setting an xp box up as a server and see if the vista box can authenticate with it, if so then maybe 2000 is the problem, sorry i couldnt give an actual solution but im still new to vista myself and dont have any pc's that will run it, my good computers are all macs.
Rating Locked! (?) ITGuru has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for Sony StorStation FSV-E1 80 GB Network
Email this problem
Email this problem
Can you Help with these Network Storage problems?
Repair Service
Find Network Storage Repairman Near You:
