Lost drive letter on computer
computer problem
I have windows xp and vista installed. yesterday I opened my computer box and it only showed my c drive. I have one more drive but it disappeared from view.
How do I get it back.
When I logged on in Vista it showed boht drive letters.
Mike
Thanks
  • 126 Answers
Sounds like you accidently deleted a mapped drive.
In explorer click tools (ALT+T)
Map new drive
select the old drive letter and location on the network
Posted on Dec 25, 2008
Hi, I've just bought a Sumvision Cyclone Primus 2TB and after connecting it to my laptop it installs the drivers. Once this is complete a Microsoft Windows pop-up comes up saying "you need to format...
Try putting the unit back on your laptop and using the windows disk management utility. The directions are below. Windows Vista is a bit differenct than either windows 7 or XP.
Right click on you "Computer" Icon in your start menu
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
See if this helps you manage the external disk and get it formatted so you can use it on your laptop.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 02, 2011 | Office Equipment & Supplies
Tip
Disk Drive Shows Up In Device Manager But Not My Computer
When you install a disk drive, Windows installs the disk drive's drivers and assigns the disk drive a Drive Letter. When your disk drive shows up in the Device Manager, but is nowhere to be found in My Computer, this means the drivers installed, but Windows didn't assign the disk drive a Drive Letter. The following procedure will help you to assign your disk drive a Drive Letter in Windows XP, Vista & 7. Note: You cannot modify the drive letter of your main partition on your PC.
Windows XP
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance. Note: If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
  8. You can now close any open Computer Management, Administrative Tools, or Control Panel windows.
Windows Vista
  1. Click on the Start button and then choose Control Panel.
  2. Click on the System and Maintenance link. Note: If you're viewing the Classic View of Control Panel, you won't see this link. Just double-click on the Administrative Tools icon and skip to Step 4.
  3. In the System and Maintenance window, click on the Administrative Tools heading located near the bottom of the window.
  4. In the Administrative Tools window, double-click on the Computer Management icon.
  5. When Computer Management opens, click on Disk Management on the left. Disk Management should appear on the right side of the Computer Management window after just a few seconds of loading. Note: If you don't see Disk Management listed, you may need to click on the '> icon to the left of Storage.
  6. On the right-hand side of the screen, locate and right-click on the drive that you wish to change the drive letter of and choose Change Drive Letter and Paths.
  7. In the Change Drive Letter and Paths window, click on the Change... button.
  8. The Change Drive Letter or Path dialog box will appear. Choose the drive letter you wish to assign to this partition. Click OK.
  9. The Confirm window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?" Note: If you have software installed to this drive, the software may stop functioning after a drive letter change. Nearly all software defaults to the primary drive though, so this is rarely a concern.
  10. If you're sure you want to make this change, click Yes.
  11. You can now close any open Computer Management, Administrative Tools, or Control Panel windows.
Windows 7
  2. Click on the System and Security link. Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link so just click on the Administrative Tools icon and skip to Step 4.
  3. In the System and Security window, click on the Administrative Tools heading located near the bottom of the window.
  5. When Computer Management opens, click on Disk Management on the left side of the window, located under Storage. After a brief loading period, Disk Management should now appear on the right side of the Computer Management window. Note: If you don't see Disk Management listed, you may need to click on the '> icon to the left of the Storage icon.
  7. In the Change Drive Letter and Paths window, click on the Change... button. The Change Drive Letter or Path dialog box will appear.
  8. Choose the drive letter you wish to assign to this drive by clicking the letter from the drop-down box on the right. Click OK.
  9. The Disk Management window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?" Note: If you have software installed to this drive, the software may stop functioning after a drive letter change. Nearly all software defaults to the primary drive though, so this is rarely a concern.
on Feb 16, 2011 | Computers & Internet
Tip
How to Install Window XP with Vista
If you wish to install Windows XP on a computer that comes with Windows Vista already installed then you will have to create a separate partition on your hard drive to install Windows XP onto. This effectively splits the hard drive into two, and keeps the different versions of Windows separate. To do this you need to open up the Computer Management screen by going to the Start menu and then right-clicking on Computer and selecting Manage.
From the Computer Management screen select Disk Management, right-click on your main hard disk where Windows Vista is installed and then select Shrink Volume. This opens up a window where you can choose how large you want the new drive partition for Windows XP to be. You need to select the size of the new partition carefully, as you will need enough space to be able to install Windows XP successfully (around 10 gigabytes) whilst leaving enough space for Windows Vista. After you have selected the appropriate amount of space click on the Shrink button to begin the process, and once that has completed you should be able to right-click on the new partition (which should be labelled “Unallocated free space”) and select New Simple Volume.
Follow the on-screen instructions to configure the partition, set a drive letter (such as E:\), give it a meaningful name such as “XP”, and then restart your computer. Whilst your computer reboots, access the BIOS and change to boot sequence to boot from your CD/DVD Drive before any other device, insert your Windows XP installation disc and then save and exit from BIOS. You will then be taken to the Windows XP installation program where you should follow the instructions until you come to the screen asking you which partition to install Windows XP to.
Make sure you select the new partition and not the one with Windows Vista installed, as this will cause problems. Once Windows XP has finished installing, you will notice that Windows XP loads up automatically, rather than giving you the choice of which operating system to use. To rectify this insert your Windows Vista installation disc and restart the computer to access the Windows Vista installation program. From the Install Now screen select Repair My Computer, and then select your Windows Vista installation and then Startup Repair. You will now be able to choose which operating system to use when your computer starts up.
on Dec 07, 2009 | Computers & Internet
How to i change the drive f back into what it was now dvd rw
If you are using Windows XP.
1. Find the 'My Computer' icon (usually located in our Start Menu)
2. Right-Click on 'My Computer' and select 'Manage'
3. Click on 'Disk Management'
4. In the bottom-right list, Right-Click the drive you want to change and select 'Change Drive Letter and Paths..."
5. Click "Change..."
6. Select a new drive letter and hit 'Ok'
7. Click 'Yes' to the warning that pops up after
You're done.
If you use Windows Vista, figure 1 below shows you how.
Figure 1:
Changing Drive Letters in Windows Vista
(http://pcsupport.about.com/od/windowsvista/ht/chdrlettervista.htm)
Here's How:
  1. Click on Start and then Control Panel.
    Tip: In a hurry? Type computer management in the search box after clicking Start. Choose Computer Management from the list of results and then skip to Step 4.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the Administrative Tools icon and proceed to Step 4.
  3. Click on the Administrative Tools link.
  4. In the Administrative Tools window, open the Computer Management program.
  5. In the Computer Management window, locate the Disk Management option on the left and left-click on it.
    If the Disk Management option is not visible, look under the Storage option by clicking the small arrow next to the word Storage.
  6. On the right-hand side of the screen, locate and right-click on the drive that you wish to change the drive letter of and choose Change Drive Letter and Paths....
    Click OK.
  9. The Confirm window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?".
    Note: If you have software installed to this drive, the softwaremay stop functioning after a drive letter change. Nearly all softwaredefaults to the primary drive though, so this is rarely a concern.
  10. If you're sure you want to make this change, click Yes. Depending on the speed of your PC, the change should be nearly instant.
  11. You can now close the Computer Management and Administrative Tools windows.
Aug 04, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
go in control panel - performance and maintanance - administrative tools - computer management- storage - disk management ! and there u can set all u;re drive letters and more ...
Dec 25, 2008 | HP Pavilion dv9000z Notebook
Can't see Seagate external hard drive on Vista devices with remov
dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 21, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
C: drive doesn't show up in My Computer
Did they reload the Windows OS on it?
Aug 21, 2008 | Acer Aspire 5100 Notebook
Freeagent tools is not working
With your XP problem..
Goto My Computer and right click.
Select Manage
In the window that opens select Storage and then Disk Management.
Your drives will be there, but need to be mounted. Right clicking on the drive will give you your options etc.
Your Vista problem I will have ot contemplate, though it's probably a software compatability issue more then anything.
Try running the EXE file under XP compatability, or check the website for an updated version. Be sure to get the 64 bit or 32 bit version as required.
Apr 21, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
